JimKiler
I recently bought a tempered glass case and i settled on the be quiet Pure Base 600 since reviews were solid and it still had two 5.25" bays so i could keep an optical drive and SD card reader. But this case only has openings on the sides of the front for air intake. Not only that but the sides are only about 50% open for air flow which you cannot tell from the pictures.
I have a Intel 4790K CPU and in my old Antec 300 i would idle around 28-32 degrees Celsius and my fans would barely spin and stop often. Now with this pure base 600 i am running all fans at least 600 RPM's and if i plan a game i can easily go up. I am idling around 36 degrees Celsius and i am hitting 60 degrees easily when playing games. I live in MN so in the winters i am not worried but this thing is going to heat up in the summer when i am too cheap to turn the A/C on. i am worried this case is not getting enough air flow. I put an extra 120mm fan to the front under the 140mm the case came with and i added a fan on the top above the CPU and opened the top of the case.
So what would you do? Return this case because airflow is not great? If I put my hand inside with the tempered glass off it feels like a lot of air moving but based on my temps going up i am nervous to use this case. I like everything about it except the temps i am getting. I ran Prime95 and my CPU was hitting 88 degrees which i know is not sustainable. I wish i had ran that benchmark while still in my old case. I can run the CPU-Z benchmark and the temp stays under 60. So am I overreacting? A lot of cases do not have a lot of airflow coming from the front at least not like my good old Antec 300. I am tempted to return this case and get what i originally wanted, a Corsair 460x, which has tempered glass in the front but is open around all four sides of the front so it should have plenty of airflow. Thoughts?
