Zepp
AppImageLauncher - Easy AppImage Integration
AppImageLauncher integrates AppImages into your Linux system, letting you run, update, and remove them easily with one click. #AppImageLauncher
appimagelauncher.com
I started to really like a new browser released last year called Helium browser, but currently they only have appimages available for linux.
If anyone else uses appimages, especially for apps that you want to integrate and update easily when new versions release (like a browser) this is a great tool.
Once installed all you do is double click an appimage file and select "integrate and launch" and it creates a Applications folder in Home, moves the appimage, and creates the .desktop file that your desktop environment uses for it's panel app menu.
when a new version of the appimage is released you simply download it, run the "integrate and launch" again and it updates to the newer appimage without touching your profile data.
Now I wish there was an app like this for tarball archives
