Johnny Lucky
Hiya Gang
I was looking at the Corsair Carbide Series Air 740 pc case. Here is a link to Corsair's web site with images of the case:
https://www.corsair.com/us/en/Categ...40-High-Airflow-ATX-Cube-Case/p/CC-9011096-WW
The bottom panel is not a plain flat panel. The bottom panel is finished similar to the front panel and the top panel. On the other hand the right panel is a plain flat panel. That would suggest the case could be rotated 90 degrees so that the plain right panel becomes the bottom panel and the motherboard is in a horizontal position.
I downloaded and looked at the owner's manual and watched numerous video reviews. One video included
a fairly good view of a case disassembly. It looked like the case could be used in a horizontal orientation.
I was wondering if anyone has tried it.
