Comdrpopnfresh
Golden Member
I have a 4x2gb set of Crucial Ballistix Tracer DDR2 DIMMs (DDR2-6400 with XMP for +DDR2-1066) from an old computer that is no longer used. Before the computer was unusable, three out of four of the sticks stopped working- the timings were not readable, and a cold boot would not work with all four in the motherboard. I am sure the memory went bad. I came to the conclusion when I had three different CPUs and 4 different LGA775 motherboards to cross-test with.
Luckily, there is the lifetime warranty. Last time I enacted my rights under warranty, an error in my favor (very Monopoly-esk) landed me the aforementioned dual set of memory from my original purchase of 4gb of Ballistix DDR-400 that ran undervolted at a CAS of 2 beyond stock frequencies.
What I would like to know is...
Are Crucial/Micron offerings in DDR still performing at or near the top? My performance goal is a frequency overclock at stock or near there-about voltages. I like to squeeze out performance, but don't like wasting kilowatts or running up a bill from HVAC in the process.
Second, with the going rates for 2-generation old DIMMs inflated as they are, I suspect I would be able to use the trade-in allowance and receive a matched pair for a 16gb set of DDR4. Does sound correct?
Ideally, I would prefer my next build to have 16-32gb of low voltage RAM that can operate at low timings and low voltage with a potentially mild overclock. It's been a while since my last build, so I would splurge on a multiplier-unlocked chip. Though, I am aiming to use AMD's coming Zen, should it release before Feb. 2107.
Should I wait it out? Use the credit for DDR4, or for storage instead?
