Hey I would really appreciate if anyone could tell me about this.
I bought one of these, And I had to return it because after two day of use at the bottom of the monitor started to appear those lines. With the warranty they send me a new one and after two days of use it did it again. the photo I attach is with the new panel.
As note bottom corners get really hot after 20 minutes of use and then these lines start to appear. I want to know if the bottom corners of your monitor get really hot, too. or if you have seen those lines. The old one panel after 7 days of use the lines dissappear but when I turn on and off the old panel those lines appear in the middle of the screen for a second. I'm getting crazy with this problem 🙁
I do not know what is happening. another note I have an I7 3370 and my motherboard is GA-Z77X-UD5H and x 2 rtx 2070, 32gb ram. I feed the monitor by two DP 1.4
Any help could be great.
