Question Fan Spec Comparisons Useless?
Mantrid-Drone
With my latest build I'm currently looking at fans, deciding what to buy. There's an aesthetic element involved but I'm most interested in performance.
I'm actually making a comparison chart of all potential 120mm and 140mm fans.
Except for Akasa few fan suppliers seem to provide noise level dB(A) figures for the range of speeds the fan supports. The figures all appear to be single figure dB(A) and CFM ratings at max RPM.
In my primary PC I have Akasa Viper 120mm CPU cooler and case fans capable of 1900 RPM, used along with a couple of 140mm (1600 RPM) case ones. I have the BIOS set to use 75% PWM on all of them and even under heavy load in the height of summer, it rarely reports four figure speeds. Even when it does they're kicking in temporarily to get the temperature down and go nowhere near their 1900 RPM max speed.
So the question: is it fair to judge a 1900 RPM fan like the Akasa Viper 120mm whose published figure is 28.9dB(A) at max speed when it is being used more typically at half that speed?
At the slowest speed supported, 600 RPM the figure quoted is 6.9dB(A).
I realise the relationship between fan speed and noise level is not linear, the figures for the Viper show that clearly but let's assume it is.
Averaging the Akasa Viper figures out using the lowest and highest numbers at 1000 RPM around 44 CFM/13dB(A) as the more typical airflow/noise level.
If you look at the Noctua NF-F12 with its stated 1500 RPM max/55 CFM/22.4dB(A) and do a quick, again linear, comparison with the Akasa Viper at 1500 RPM the Akasa appears significantly better at 66 CFM/17.68dB(A).
The better spec Noctua NF-A12 figures using the same criteria are 45CFM/16.95dB(A) ie. near enough the same noise level but 30% less airflow.
At 1000 RPM the NF-A12 beats the Akasa Viper on noise at 11dB(A) so it is quieter but again the, roughly calculated, airflow at that speed is 30 CFM, 33% less.
Of course this all relies on manufacturers' figures being trustworthy. If you accept they are: surely just comparing fan dB(A) and CFM at max speed is not like for like and therefore useless to potential customers. Wouldn't both max and min CFM/dB(A) figures be more helpful? Why not a mid-range figure like 1000 RPM (for 120mm fans) too?
While I can accept that cheap sleeve bearings are made of plain metals, the most common version of those I encountered for decades was what I called "Oilite" bearings. These were brass sleeves around a steel shaft, but the brass was cast in a particular way to include microscopic porous voids, then soaked in hot oil for a time before installation. That had the effect of providing an invisible oil reservoir in the bearing sleeve. Still, those hearings did require re-oiling over their lifetime. In smaller items they usually were so securely fastened into the frame they were permanent. Sometimes the mounting location included space and a felt pad as an additional oil reservoir. In some large applications they were press-fit into the frame ends and you could actually remove them and re-install them. Some people believed (not sure whether true or not) you could renew the original oil load. They would remove the bearing sleeves, clean them thoroughly to remove accumulated dirt and microscopic metal, then soak them in hot light oil for days before re-installing. Such porous brass Oilite bearings were supposed to last much longer than plain bare metal sleeves because of the built-in oil reservoir system. A further feature was that the brass wore down faster than the steel shaft, so if the bearing sleeves you had could be removed, when they became so worn as to develop excessive clearance you could replace the sleeves. Of course, this type still did not last as long as ball or roller bearings, and wore out much faster in high-load applications. It appears to me the Fluid Dynamic Bearing and Rifle Bearing designs are just attempts to improve that older design. In fact, I wonder whether the "plain" bearings of today still use that older design I called "Oilite".
We should bear in mind also that much of this discussion is about use of fans with their shafts HORIZONTAL. When fans are used in other orientations, the load of the rotating shaft presses on other surfaces than a simple sleeve around the shaft, and that load-bearing surface needs consideration of a bearing arrangement. This applies also to ball and roller bearings. If you go to buy those designs for heavier loads, one important question is always "axial load or radial?"
I mentioned that horizontal or upright fan matter in relation to the FDB types which, being sealed ensures the lubrication oil doesn't leak out. As ^^ said earlier capillary action along with purpose designed channels should mean the whole shaft is kept lubricated, at least when running.
The most interesting alternative technology I've come across is the "POM" bearing ie. polyoxymethylene "self-lubricating" used by some Cooler Master fans.
It has been around for years but has not taken the PC fan manufacturing world by storm.
^ I have to trust that MAJOR fan manufacturers, who make their living selling fans rather than various PC accessories and parts, have done due diligence and researched plastic bushings in the past and found that the slight cost savings isn't worth it - except to coolermaster who is trying to shave pennies off.
Oilite is but one brand of the sintered bronze bushing prevalent in (almost) all sleeve bearing fans these days.
The issue is that if the manufacturer tries to cheap out too much, the bushing may have a bad grain structure, or poor tolerance, or the fan blades are imbalanced. All these things (and more like ambient temp) can effect the serviceable lifespan or interval between which they need relubed. Another way the manufacturer tries to cheap out is use of smaller shaft and bushing, note how Panaflow had used a lager diameter shaft and bushing.
Sealed doesn't really mean much, may even be the worst option. A fan with decent plastic molding tolerance and a good quality rubber plug over the bung hole, won't leak out there, but if you remove that plug/access so it's "sealed" then it can't be relubed (easily) and still has the same more likely leaking area which is the other end which seals against, and wears from friction once low on lube.
Granted this is within the context that if someone cares, they relube their fans every once in a blue moon instead of just running them till they seize up. By relubricating them, you *almost* guarantee they won't ever seize up.
Relubricating a sleeve bearing fan is by far the best alternative. If you do it often you can use a low viscosity oil that seeps into the bushing more, but the longer you wait and the more wear there is, the more likely you will need a larger amount of lube and a higher viscosity to make up for the slack in the bearing, which will still reload itself with oil.
I should clarify that. The higher viscosity should come from the same low viscosity base oil, but more solids from grease additives. This results in the low viscosity that seeps into the bushing well, and the grease solids act as a carrier in the case of cheaply designed PC fans that don't have a sufficient reservoir with a felt/etc material to hold as much oil otherwise.
I have never had a single major brand, bronze bushing fan that was relubed as needed, fail. Heh, I've even had some fans that did fail, seized up, burnt up a PSU that someone brought to me, cleaned them out and relubed, and the fans still work.
I'd rather just have a dual ball bearing fan from a major fan manufacturer. That is what you find in any high end equipment where pennies aren't pinched, with the one exception behing high shock environments that might deform bearings. That tends to be vehicles not stationary objects.
Obviously there is much to disagree about, fans and bearings can't be thoroughly enough discussed in a few forum posts. I suppose I'm back to my main point that I don't see the obsession with seeking a lighter duty fan with marketing pimping it, when the noise vs airflow difference at its normal reduced-RPM speed (keeping the PC components at an acceptable temperature) isn't much.
I've been collating some of my fan manufacturer's spec results and no matter how I skew the rating system the best balanced performance Be Quiet (SW3) fan always seem to come out on top by some margin.
The problem with that is in the course of my investigations I'd come across a review of Be Quiet fans by a guy who it read like he knew what he was talking about.
He claimed to be a sound engineer and didn't like them for a rather prosaic but nonetheless apparently good reason. The particular low and high frequency noise they, allegedly, produce, just at the edge of the normally audible range for an adult, is enough to cause not just annoyance but actual hearing damage.
I take such reports with a healthy degree of skepticism but what I do know is that the frequency of the noise made by a fan is something other informed fan reviewers say is something to consider.
But how you do that without buying a particular fan or fans and testing it/them against a known fan you're happy with is not explained. But it leaves you having to decide whether to take such warnings from reviewers seriously.
BTW the Noctua P120 IND fan spec figures suggest it has the best balance of performance with regard to dB(A) of their 120mm range. Those figures are actually better than the claimed 'quiet' fans from over 50% of the other (11) manufacturers fan specs I've been looking into.
It is still far behind the Be Quiet SW3 but overall the same score as the Akasa Viper both only marginally behind the the best Corsair, Thermaltake and temptingly cheap Arctic P12 PST.
If you exclude the cost factor the Arctic does not fair so well but at 75% less than the cost of the Noctua fan and 50% - 60% less than most others you cannot ignore them.
^ If the source claims that the minor drone of a PC fan, based on frequency, will cause hearing damage, you should reject everything he stated as unreliable.
At the same time, yes some frequencies are more objectionable to some people, particularly higher frequencies to younger people with more acute higher frequency hearing. At the same time, higher frequency sound is more directional and more easily mitigated based on fan placement or system placement... and really I'm only talking about there being a significance with nearly worn out ball bearing fans, then they start to whine a bit. They do make the whine at lower RPM too, but it is so much reduced that at average system cooling requirements, it is practically inaudible.
Long story short, it seems a lot like you are just chasing numbers on paper and not putting much real world perspective into this, while also expressing a desire for long lifespan which is more likely with a major brand fan that doesn't have the best noise to airflow ratio, because it is optimized for lifespan rather than that, or construction cost.
It comes back to that old saying, pick two of the three: Performance, lifespan, or cost... except that when it comes to PC fan 3rd party marketing agencies, they feel they can charge more based upon the new internet game, of promotion and well placed reviews.
Even so, a reputable PC parts branded fan, priced at a premium, should be expected to have "enough" service life and focusing on noise isn't unreasonable... but I don't think that's going to matter much unless the system in question has large thermal changes where the fan is likely to spin up to full speed often.
TBH I'd be happy with all 140mm Akasa Viper case fans and may be a couple of their 120mm (better SAP) on the cooler. That's simply because of my past and continuing satisfactory experience with them.
But I as said wanted to find something noticeably quieter but of similar performance and not bright yellow.
That's the problem because you're doing little more than guessing from the manufacturers' specs supplied that the performance is going to match or be better, have good build quality, be equally reliable, proven longevity and less dB(A).
Short of the unwanted expense of buying a fan of each make/type/size that seem to fit those criteria and testing them myself what else can you do other than collate and compare manufacturers' specs?
Lets face it most people just buy whichever fans they're told are good (typically Noctua). If they get on with them, and its highly likely they will, keeping their system adequately cool they'll be, quite literally, a fan for life.
But the fact is they are out performed by some other manufacturers' products, often at a much lower price too.
Its the inadequate information that is the problem here really. As I also said earlier if every fan manufacturer supplied AF, SAP, CFM and dB(A) figures for an agreed mid-range RPM speed typical of normal use ie. 1000 rpm you'd be able to compare the fans' 'real life' performance much more reliably.
As it is you can have a Phanteks 2000 rpm/3.59 mm H20/93 CFM 140mm fan producing 39.1dB(A) at that full speed being sold as "a quiet fan". How on earth do you compare that with, for example, the Akasa Viper 140mm: 1600 rpm/3.1 mm H2O/110.61 CFM and 26dB(A)?
Today it is far easier to just pick the right case and mod it if necessary, more important than fan choice.
Most people buy the fan and then strap it onto a heatsink with insufficient case noise containment, or on a perforated case wall intake/exhaust grill, and the turbulence from that swamps minor differences in fan free-air noise ratings between different fan models (all else equal, size and RPM).
I present a 25 year old case setup that had a lot going for it to reduce noise.
Rear fan hole cut (there wasn't a fan mount there at all) as well as PSU stamped grill cut out... well, the entire PSU case opening was cut out too, formerly used a proprietary smaller PSU and now ATX.
Thick 1.0 - 1.2mm metal, and plastic clad combined so less vibrations, but not a lot of passive holes to let interior noise escape.
Fans upper limited by 5 cent resistors in series
Make airflow most effective by entering only at the opposite end and flowing through the HDD rack, instead of just tossing a half dozen giant fans everywhere.
No forward facing grill for sound to escape with line of site/ear to the user, rather intake up through the bottom, and perforated case wall, grill area cut out.
To test things you can get output values using linux / sensors and a vareity of other apps to display vital stats on the system.
CFM usually means good temps under load which would mean using some load producing apps which are easily installable on livecd just like they would be if you installed Linux w/o the need to use a spare drive to do so. As soon as you reboot you're back to your normal system.
If it really just comes down to the color of the fins though just spray them whatever color you want them to be and be done with it.
Interesting you should mention that - there's a Cooler Master fan type: Blade Master, very difficult to find in the UK now except as part of on eof their cooler/fan packages so I didn't bother to look at its specs too closely. It also uses very similar 'S' shaped to the Akasa fans.
Anyway one of the things that caught my attention was one of the fan blades looked to be etched, deeply with a branding logo.
The first thing I thought was: doesn't that affect the balance? Surely it must effect the efficiency creating disruption in the airflow over that particular blade?
Interesting you should mention that - there's a Cooler Master fan type: Blade Master, very difficult to find in the UK now except as part of one of their cooler/fan packages so I didn't bother to look at its specs too closely. It also uses very similar 'S' shaped to the Akasa fans.
They can just design the mold to have that little bit extra material on that side to offset the text, though something else I've seen on some fans is some type of epoxy or adhesive added to the inner hub to precision balance it.
Yes it would cause a little turbulence, but apparently coolermaster didn't care that much to begin with because they chose a softer plastic with a textured molding... note how the blades aren't perfectly smooth. That can help reduce vibrations a little if used on the frame but not so much on the blades.
Just finished collating my ranking results using the manufacturers' spec for their 'best' 120mm PWM balanced performance fan and it is quite interesting. The mistake I made, then corrected, was treating the RPM range as a positive feature so the fans with higher top end and a low bottom end speed were unduly favoured.
The correction simply used the top speed (which is used almost exclusively for all their AF/SAP/dB(A) specs anyway) as a negative ie. the higher the top speed the lower the ranking. This seems fair treatment.
The precise detail and scorings are not really important but I think I've been fair and the results are useful (to me at least) comparisons of the fan manufacturers' figures.
For those interested my top three balanced performance 120mm PWM fans based on the manufacturers' published data are:-
1. Be Quiet Silent Wings 3 HS (BL070).
2. Akasa 12cm Viper (AK-FN059).
3. Noctua NF-F12 IND (NF-F12-IND-PPC-2000 PWM).
Now to do the 140mm PWM ones.
Just finished doing that:-
1. Akasa 14cm Viper (AK-FN063).
2. Scythe Kaze F Round (KF1425FD18-P).
3. = Be Quiet Silent Wings 3 HS (BL071).
Thermaltake Toughfan 14 (CL-F18-PL14BL-A)
The Akasa walked away with it in the 140mm tests - miles ahead of the nearest opposite with, surprisingly, the Scythe coming second mainly due to its reasonable pricing and relatively low dB(A) rating at top speed.
The Noctua FN-A14C came nowhere even when the high cost was factored out.
The Thermaltake costs more in the UK than any of the fans compared but when that is factored out it would move up to clear second place relegating the Scythe to third and the Be Quiet out of the top three.
As an addendum to this:-
For my latest PC build I'm currently buying the parts, slowly, and I came up against this fan matter again. I've collated new comparison figures for some more current fans like the Be Quiet Silent Wings Pro 4 120mm/140mm and some others but still getting the Akasa Viper range coming out on top.
Bizarrely the Be Quiet 140mm SW Pro4 at its top speed (2400rpm) is actually the noisiest fan in the whole test at 36.8dB(A).
The problem now with the Akasa Viper range is that they seem to have stopped manufacturing them, the standard frame 140mm is practically unobtainable new in the UK. The 120mm mounting frame, with marginally inferior figures, the 140mm Viper R, is still around but in much reduced quantities.
I would to go to them again but TBH I really want a change in aethetics - poison yellow fans if you're not bothered about the colour or are using that as part of a personalised colour scheme OK. But it stretches understanding of the marketing strategy that they didn't make the same fans in both sizes in inoffensive black at the very least.
And why they use mud brown fan connectors plugs for all their fans is another irksome and inexplicable oddity if you're colour customising your PC.
Anyway my choice this time is to get away from the yellow beasts and go for a matching black and white fan mix. The 120mm white Vipers, good for cooler use, can still be found in three packs but I needed some 140mm case fans too. So I've gone for the 'lower' spec Akasa, oddly named, Apache range,. They're only found in black and again, now, in limited quantities but which use the same S-Flow fan blade and general design.
Downside is that they operate at a lower maximum speed than the equivalent Viper. They could have called them Silent Viper but their marketing division obviously didn't think of doing that.
The fact is their adjusted performance figures are not that much different from the 140mm Vipers and, on paper, actually should still produce an effective, likely quieter and without a doubt cheaper cooling system than the much more expensive all Be Quiet 120mm/140mm solution I had been considering.
This is an older thread but I was reviewing it, NOT having remembered I had contributed a few posts. What I just noted was many posts talking about the virtues of bearing types and how re-lubricating them impacts those designs. That kind of discussion really has NOT been relevant for some time now. I did that sort of thing back in the 1990's when you could actually disassemble a fan to reach bearings to clean and re-oil them. I still do this often now with desk-top room fans etc. But in those days the fan motors all had fixed field magnets and commutators on the moving rotors to switch connections to the coils. For decades now the design has changed fundamentally to eliminate moving contact surfaces in a commutator system (which will wear out eventually) with electronic switching of power to the electromagnetic coils. In this design the permanent "field" magnets now are on the ROTOR and the electromagnetic fields that move are generated by STATIONARY coils fed by those electronic switching circuits. These circuits use a small sensor (Hall effect?) for the rotational position of the rotor to synchronize the changing field coils to the rotor movement. The design completely eliminates wear in a non-existing commutator / brush system.
Simultaneously with that change, fan makers also changed the way a fan case is assembled. There are no longer any screws holding things together, and no set-screw fixing the fan blade assembly to the shaft. It's all press-fit and latching tabs, and very often actual "welding" of plastic case parts either with adhesive of by heat. The result is that you can NOT expect to disassemble any modern computer case fan safely while preserving its integrity so that you can re-assemble it after service work. So there is no way to access the bearings and shaft ends for cleaning, re-oiling and re-assembly. I know some people have tried a different approach with no attempt to open up the fan chassis. They just drop or spray light oil into whatever cracks appear in the fan chassis and hope that will make its way inside to the bearings. But what that does IF SOME OIL ACTUALLY PENETRATES really is to spray oil EVERYWHERE inside the fan chassis, which you never should do!
Net result: with modern computer fans there is NO way to re-oil any bearings. You MUST rely solely on what the manufacturer installed. When the fan bearings wear excessively or dry out, your only path is to replace that fan.
?? Have to disagree. I've relubed so many fans, that I literally have different bottles of lube based on what viscosity the lube is, because the more worn the fan is, the higher the viscosity of optimal lube is.
The relevant wear for PC brushless fans (same design used for ~40 years) is the bearing itself, not non-existing commutator/brushes. The bearing itself eventually runs out of lubricant and essentially chews itself up, resulting in either shaft seizure or creating an elliptical wear pattern and wobbling, more, and more for a while, then still eventually seizes.
You must need more sleep or something, because the vast majority of PC fans have a sticker, then if sleeve rather than ball bearing, a rubber plug that is removed, which allows to lubricate them. There are a few upper tier, but mostly the cheapest of fans that have done away with this access hole, making them permanently sealed, but this "lubed for life" design is sort of the way that many industries have gone by making non-serviceable components just to save a minimal amount of money and then end of life comes sooner because it can't be relubed.
It's perfectly safe to do, easy, and completely intact when finished. If the relube is done before the wear gets too bad, you can pretty much keep the fan running *forever* by continuing to relube it periodically. The worse you let it wear between lubes, the sooner it will need lubed again so the best practice is not to wait until it's so dry that it's damaging the bushing.
Further on this most common fan design, whether sleeve or ball bearing based, if you wish to further disassemble it, there is either a plastic or metal clip that once removed, allows pulling the entire hub and blade assembly out of the bearings - but this is not necessary on sleeve bearings because any lube added through the access hole will wick all the way through the bearing, even into it as they are almost always sintered bronze on typical sleeve bearing fans (regardless of the fancy marketing name they happen to use for their sleeve bearing). Some are of course different bearing material like ceramic, or even plastic on extremely cheaply made fans, but they are the rare exceptions as they don't save that much on the BOM to make a fan.
If a fan gets so bad that it seizes, or is wobbling badly, then in theory it might be beneficial to clean out the bearingway, but in practice if a fan has gotten that bad, I'd just replace it.
If you catch the wear before it is that bad, I've never had a problem with only relubing, not attempting to clean out the bearing first. Reassembly is then only a matter of slapping the rubber bung plug back in, or if you're picky, trying to get the sticker covering it to adhere again. Better quality fans tend to have a molded rubber plug with some depth to it, that fits securely into the hole and does a fair job of sealing, while the cheaper fans may use a flat piece of rubber that depends a bit on the sticker to hold it flush against the molded plastic.
I have no idea where you're getting this idea from. You cannot reasonably relube ball bearing computer fans because the bearings themselves, not the whole fan, are sealed (and unlike larger sealed ball bearings, the seals are so tiny that if you tried to pry them out, you'd likely damage them too much to seal again), but you can still access those ball bearings, and "almost" all sleeve bearing PC fans can be relubed, though again I think of a rare exception that some might have a teflon bushing and a dry lube like graphite if any.
Let's see if I can find a representative pic... okay here's the first topic I see about it:
However, don't take some of the advice in that topic. Very thin oil is only good to relube fans with practically no wear, then once there is wear, the viscosity needs to have a film strength sufficient to buffer the play worn into the bearing, but especially don't make a lube mix that is oil mixed with (silicone based) dielectric grease. Regular grease will mix fine but dielectric grease and petroleum oil don't mix well at all.
