Zepp
I started noticing this issue a week ago or so and it's basically made gecko based browsers a no go to me for the time being.
With several tabs open, quickly moving the mouse to select another tab often makes my cursor hit the top of the screen. For some reason the way gecko browsers work in linux it can too frequently not register that the cursor is over the tab, so you click to select or middle click to close and nothing happens. It requires you to avoid the top pixel space of the tab to consistently register the click.
I troubleshot with chatgpt for a while and it basically said, it's a gecko browser thing on linux, you cannot completely fix it, only mitigate it. but none of the mitigations worked well enough for me to continue to use these browsers.
On windows this is not an issue as I use Floorp at work and never experience it. Also I never get this issue with chrome/blink based browsers on Linux or Windows.
Really sucks because I was just looking forward to going back to gecko(Waterfox to be exact)
Have you other linux users noticed this issue?
