thedighubs
hello dear all good day dear experts of the AnandTech-forum, 🤩
i am currently workin on some test-images - i want to learn more about color gradients. How to create them - how to create such - with a certain color sheme!?
i want to replace this color-sheme with another one - that is good looking. So i need to re-create the background.
btw: what if we want to use some colors - of perhaps some similar of the following - can i do this
sunrise Gradient-color-Sheme:
cf. https://www.schemecolor.com/sunrise-gradient.php
2D1D7A - 804565 - AA585B
i guess that this is possible to do such a color - gradient.
look forward to hear from you
yours matze
Sunrise Gradient Color Scheme
update: see The Sunrise Gradient Color Scheme:
see more of the ideas: ...
Well - what is wanted and what is aimed: i want to create a color gradient with the above mentione so galled "Sunrise Gradient" color scheme using the mentioned (and above provided ) hex codes (2D1D7A, 804565, AA585B)
i guess that i can work with those data - in the graphic-editor - my GIMP or incscape or even Krita:
.i guess that the most image editing and design software provides such tools to define gradients using the so called color stops and their corresponding positions.
So i thought that i should be able to input these hex codes as the colors for a gradient stops, and then adjust the positions along the gradient to achieve the desired effect.
working with the Color Stops: (note - as mentioned above: this is only a example-color-sheme and subsequently all the color-stops are only examples)
Afaiik Gradients are defined by color stops, which are points along the gradient where a specific color is applied. While we can have multiple color stops to create a smooth transition between colors i think that at least two or three are sufficient to work well. What do you say here?!
i think that i could work with the Gradient Editor: in fact: i think that i am going to use ( GIMP, Inkscape or Krita etc.) - those packages have a gradient editor that allows me to define color stops. On a sidenote: i guess that GIMP is easier than Inkscape: I need to add the mentioned color stops, adjust their positions, and change the color associated with each stop.
Applying the Sunrise Colors:
In the gradient editor, we should be able to add one or two (or hmmm even three) example (!!!) color stops, one for each hex code.
Stop 1: Assign the color 2D1D7A.
Stop 2: Assign the color 804565.
Stop 3: Assign the color AA585B.
/(note: as mentioned above: these are example-color-shemes and color-stops)
the question is: can i then adjust the position of each stop (e.g., 0%, 50%, 100%) to control the color transition.
furthermore - and another question: can i add some kind of gradient type too:
Am i able to choose from different gradient types, such as linear, radial, or angular. I guess that the so called linear gradients create a straight color transition ( while radial gradients radiate from a central point). At the moment i do not need any further adjustments:
regarding the tool - which one do you suggest to use: GIMP or Inkscape - or even Krita!?
I guess that GIMP is a bit easier to use - for this kind of project.
Look forward to any and all ideas
yours matze
cf https://www.schemecolor.com/sunrise-gradient.phphas 6 colors, which are Persian Indigo (#2D1D7A), Imperial (#573170), Deep Ruby (#804565), Middle Red Purple (#AA585B), Copper Red (#D36C50) and Mango Tango (#FD8046). The RGB and CMYK values of the colors are in the table below along with the closest RAL and PANTONE® numbers. Click on a color chip to view shades, tints and tones, and also download patterns, gradients and palettes of the color.
