How to use CUDA programming to calculate and process the correct number
Tron Orino Yeong
Bandwidth test - test memory bandwidth.
Especially important for PCIE capability. Different MB has different PCIE capability.
The CUDA adaptor performance is depend on the capability of PCIE. It could be the performance bottleneck.
On the following programming drills, the number of clock cycles necessary for computation and utilised memory bandwidth have to be computing.
(1) parallelization in the programs - using 256 threads
(2) improving the memory access modes
(3) testing the parallelization by using 512/1024
(4) utilizing BLOCKS in the computation
(5) utilizing shared memory
(6) improving the computation oerfdormance by using a Treesum algorithm
(7) resolving the memory band conflict issue, encountered in applying Treesum algorithm with the shared memory
I get some errors for my coding sample as below -
#include <stdio.h>
#include <stdlib.h>
#include <cuda_runtime.h>
#include <time.h>
#include <math.h>
#define DATA_SIZE 1048576
#define BLOCK_NUM 32
#define THREAD_NUM 256
int data[DATA_SIZE];
bool InitCUDA()
int count;
cudaGetDeviceCount(&count);
if (count == 0)
fprintf(stderr, "There is no device.\n");
return false;
int i;
for (i = 0; i < count; i++)
cudaDeviceProp prop;
if (cudaGetDeviceProperties(&prop, i) == cudaSuccess)
if (prop.major >= 1)
cudaGetDeviceProperties(&prop, i);
printf("Device Name: %s\n", prop.name);
printf("Total global mem: %1u bytes\n", prop.totalGlobalMem);
printf("Max threads per block: %d\n", prop.maxThreadsPerBlock);
printf("Clock rate: %.2f GHz\n", prop.clockRate*1e-6f);
printf("\n");
break;
cudaSetDevice(i);
return true;
__global__ static void sumOfSquares(int *num, int* result, clock_t* time)
const int tid = threadIdx.x;
const int size = DATA_SIZE / THREAD_NUM;
int sum = 0;
int i;
clock_t start;
if (tid == 0) start = clock();
for (i = tid * size; i < (tid + 1) * size; i++)
sum += num * num;
result[tid] = sum;
if (tid == 0) *time = clock() - start;
int* gpudata, *result;
clock_t* time;
cudaMalloc((void**)&gpudata, sizeof(int)* DATA_SIZE);
cudaMalloc((void**)&result, sizeof(int)* THREAD_NUM);
cudaMalloc((void**)&time, sizeof(clock_t));
cudaMemcpy(gpudata, data, sizeof(int)* DATA_SIZE, cudaMemcpyHostToDevice);
sumOfSquares << <1, THREAD_NUM, 0 >> >(gpudata, result, time);
int sum[THREAD_NUM];
clock_t time_used;
cudaMemcpy(&sum, result, sizeof(int)* THREAD_NUM, cudaMemcpyDeviceToHost);
cudaMemcpy(&time_used, time, sizeof(clock_t), cudaMemcpyDeviceToHost);
cudaFree(gpudata);
cudaFree(result);
cudaFree(time);
int final_sum = 0;
for (int i = 0; i < THREAD_NUM; i++)
final_sum += sum;
printf("sum: %d time: %d\n", final_sum, time_used);
final_sum = 0;
for (int i = 0; i< DATA_SIZE; i++)
sum += data * data;
printf("sum (CPU): %d\n", final_sum);
int sum = 0;
int i;
clock_t start;
for (i = tid; i< DATA_SIZE; i += THREAD_NUM)
sum += num * num;
result[tid] = sum;
const int bid = blockIdx.x;
int sum = 0;
int i;
if (tid == 0) time[bid] = clock();
for (i = bid * THREAD_NUM + tid; i< DATA_SIZE; i += BLOCK_NUM * THREAD_NUM)
sum += num * num;
result[bid * THREAD_NUM + tid] = sum;
if (tid == 0) time[bid + BLOCK_NUM] = clock();
clock_t* time;
cudaMalloc((void**)&result, sizeof(int)* THREAD_NUM * BLOCK_NUM);
cudaMalloc((void**)&time, sizeof(clock_t)* BLOCK_NUM * 2);
sumOfSquares << <BLOCK_NUM, THREAD_NUM, 0 >> >(gpudata, result, time);
int sum[THREAD_NUM * BLOCK_NUM];
clock_t time_used[BLOCK_NUM * 2];
cudaMemcpy(&sum, result, sizeof(int)* THREAD_NUM * BLOCK_NUM, cudaMemcpyDeviceToHost);
cudaMemcpy(&time_used, time, sizeof(clock_t)* BLOCK_NUM * 2, cudaMemcpyDeviceToHost);
cudaFree(gpudata);
cudaFree(result);
cudaFree(time);
intfinal_sum = 0;
for (inti = 0; i< THREAD_NUM * BLOCK_NUM; i++)
final_sum += sum;
clock_t min_start, max_end;
min_start = time_used[0];
max_end = time_used[BLOCK_NUM];
for (inti = 1; i< BLOCK_NUM; i++)
if (min_start > time_used)min_start = time_used;
if (max_end < time_used[i + BLOCK_NUM])max_end = time_used[i + BLOCK_NUM];
printf("sum: %d time: %d\n", final_sum, max_end - min_start);
extern __shared__ int shared[];
int i;
shared[tid] = 0;
shared[tid] += num * num;
__syncthreads();
if (tid == 0)
for (i = 1; i< THREAD_NUM; i++)
shared[0] += shared;
result[bid] = shared[0];
clock_t* time;
cudaMalloc((void**)&result, sizeof(int)* BLOCK_NUM);
sumOfSquares << <BLOCK_NUM, THREAD_NUM, THREAD_NUM * sizeof(int) >> >(gpudata, result, time);
int sum[BLOCK_NUM];
cudaMemcpy(&sum, result, sizeof(int)* BLOCK_NUM, cudaMemcpyDeviceToHost);
cudaFree(gpudata);
cudaFree(result);
cudaFree(time);
int final_sum = 0;
for (int i = 0; i< BLOCK_NUM; i++)
final_sum += sum;
__global__ static void sumOfSquares(int*num, int* result, clock_t* time)
int i;
into ffset = 1, mask = 1;
shared[tid] = 0;
__syncthreads();
while (offset < THREAD_NUM)
if ((tid& mask) == 0)
shared[tid] += shared[tid + offset];
offset += offset;
mask = offset + mask;
__syncthreads();
if (tid == 0)
offset = THREAD_NUM / 2;
while (offset > 0)
if (tid< offset)
offset >>= 1;
__syncthreads();
if (tid < 128)
shared[tid] += shared[tid + 128];
__syncthreads();
if (tid < 64)
shared[tid] += shared[tid + 64];
__syncthreads();
if (tid < 32)
shared[tid] += shared[tid + 32];
__syncthreads();
if (tid < 16)
shared[tid] += shared[tid + 16];
__syncthreads();
if (tid < 8)
shared[tid] += shared[tid + 8];
__syncthreads();
if (tid < 4)
shared[tid] += shared[tid + 4];
__syncthreads();
if (tid < 2)
shared[tid] += shared[tid + 2];
__syncthreads();
if (tid < 1)
shared[tid] += shared[tid + 1];
__syncthreads();
@Tron Orino Yeong this appears to be a homework problem. We don't answer homework problems in their entirety. Do you have a specific question about your homework? -- Programming Moderator Ken g6
