I7 3960x running at 4.2 instead of 4.6 while gaming
Henmen123
I have an Asus x79 rampage 4 micro atx motherboard and the 3960x processor. I would like to overclocking with speedstep and offset voltages but when I overclock with this method it will only run max speed 4.6 when I use prime 95. While gaming and most other tasks it runs at 4.2. It is not a throttle issue. If I run in high performance power mode in Windows it runs at 4.6 accept at all times. I am annoyed right now so I just lowered the overclock to 4.2 but I would like to run it at the higher speed. I tried disabling cstates with no change. I have the latest bios would downgrading to an older one change anything? Thanks for the help
Noticed a similar issue with a E5-1660 on a Sabertooth X79 and Win7.
Currently running 47x100, +112mV turbo voltage offset, default LLC, 0 core voltage offset, 1.2V VCCSA and VTTCPU, DDR3-2133 10-12-12 @1.65V.
Using single threaded IBT as an example here, but any benchmark, application or game that doesn't fully load all cores seems to be affected to some degree.
C-states, C1e, C3, C6, C7 and package C-states enabled, EIST enabled, default "balanced" windows energy settings:
30.6-33.1 GFLOPS, often not seeing more than 4.4GHz max freq, 1.2 idle. HWiNFO shows ~8W CPU package power idle@desktop.
Energy settings min cpu frequency set to 100%:
33.7 GFLOPS, solid 4.7 under load, 1.2 idle. ~9W idle.
C-states disabled, EIST enabled, default energy settings:
23.5 GFLOPS. Runs at 3.3 with single threaded loads (?!?), 1.2 idle. ~24W idle.
C-states disabled, EIST enabled, min cpu frequency 100%:
33.1 GFLOPS. Solid 4.7. ~95W idle.
C-states and EIST disabled, default energy settings:
C-states and EIST disabled, min frequency 100%:
C-states enabled, EIST disabled, default energy settings:
33.7 GFLOPS, 4.7 under load, 1.2 idle. ~9W idle.
C-states enabled, EIST disabled, min frequency 100%:
My conclusions:
There appears to be some odd interaction between task migration across cores and Windows CPU frequency scaling.
Disabling C-states massively increases CPU idle power usage and reduces single threaded performance (huh?), so I'd prefer to keep them enabled.
EIST is what enables OS controlled dynamic freq scaling.
So I've settled on running C-states enabled, EIST disabled, default "balanced" energy plan.
Alternatively, C-states and EIST enabled, energy plan min CPU frequency set to 100% would achieve the same result - OS-controlled dynamic frequency scaling neutered while still allowing idle cores to power down.
