toozeddyforyou
My Macbook pro 2011 was water damaged, i ended up fixing it with alcohol and It started working. it ended up being that the battery was faulty anyways so i would disconnect it and the Macbook would run on full speed.
So I ended up getting another battery and it would work but the trackpad and keyboard wouldn’t work, only on the login screen and when i login it would stop working, i tried restarting the SMC and PRAM nothing happened.
Now that i got the new battery the whole thing wont turn on. battery unplugged nothing, the charger shows a dim green light, Fans won’t spin nothing. Anything i can try doing? Cheers!
You already have a thread about this. Post any additional information in it.
admin allisolm
admin allisolm
