Need Advice about motherboard for LIDAR Surveying
dinoarmas
I am spec'ing out a computer for my work desktop PC that my company will purchase. I am processing very large LIDAR point clouds for surveying purposes. Please advise on where I can go to compare motherboards. I would like to have a complete list of motherboards that have these boxes checked off.
  • Has dual Xeon chip sockets
    M.2 NVMe gen3 SSD slot (that can utilize a 2TB+ if that is a concern)
If anyone could recommend which Xeon CPU and RAM would pair nicely with any motherboard that you recommend that would be appreciated as well.
I don't imagine that there is a long list of motherboards that have these requirements. Being that M.2 NVMe SSD's are fairly new.
The bottle neck I am worried about is the read & write speeds to storage from the CPU. I know I could do some type of RAID setup but would like to worry about that at a later time. Just want to get the fastest CPU to a single storage drive speeds as possible.
Give that a carefull read before you buy anything:
https://forums.freenas.org/index.php?threads/m-2-ssds-and-x11ssh-f-motherboard.41592/
https://www.newegg.com/Product/Prod...=dual_xeon_motherboard-_-13-182-927-_-Product
SuperMicro recommends samsung memory, for it but call them directly and find out for sure.
https://www.newegg.com/Product/Product.aspx?Item=N82E16820147591
https://www.newegg.com/Product/Prod...escription=ssd+m.2&ignorear=0&N=-1&isNodeId=1
Tel: +1-408-503-8000
Super Micro Computer, Inc.
980 Rock Avenue
San Jose, CA 95131
