Priya Patel
I need suggetion and Help my New Build:
Here is My Configuration which i want to buy.
confused to selection buy Case(Cabinet).
My Spec:-
CPU: AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor (Item model number :- YD2700BBAFBOX) with Included Components : Processor, CPU Cooler
Motherboard: Gigabyte B450 Aorus Pro WiFi rev1
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory
Storage (SSD): Western Digital - Green 240 GB 2.5" Solid State Drive
Storage (HDD): Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
Video Card: Zotac - Zotac Amp Edition GeForce GTX 1060 6GB DDR5 PCI-e Graphics Card with IceStorm Cooling
Power Supply : Corsair VS550 550-Watt Power Supply
and here Confused with Cabinet :-
im not willing to spend too much on Cabinets
Here are Written Case Names and Link which is good looking and lower Price.
1) Corsair - SPEC-01 ATX Mid Tower Case
2) CHIPTRONEX X410B MID TOWER GAMING CABINET CASE USB 3.0 WITH LED FAN WITHOUT SMPS
3) CHIPTRONEX Ghost GNX200 Mid Tower Full ATX Gaming Cabinet with Matte Glass Front and Top Panel/Transperent Side Panel with 3 LED and Fan Controller
https://www.amazon.in/dp/B078Z6ZJGQ...&pd_rd_r=5ac32ade-0b36-11e9-8210-ed08ba772cb1
4) CHIPTRONEX GX1000 V2 Mid Tower ATX Acrylic Side Window Gaming Cabinet with 2x120mm Red Led Fans, 1x120mm USB 3.0 Normal Rear Fan with Speed Controller
https://www.amazon.in/dp/B075V7FZ63...&pd_rd_r=5ac32ade-0b36-11e9-8210-ed08ba772cb1
5) BBC Gaming Cabinet 8804 With 3.0 USB And Side Acrylic Panel Without Power Supply
https://www.amazon.in/gp/product/B075CQRD4P/ref=ask_ql_qh_dp_hza
Tell me which is supported cabinet for Configuration.
and yahh , i Also work and Gaming for 8 to 10 Hours a day, does it need liquid cooling.? or it'll be fine with AMD Cooling Fan.
because i want to add Liquid cooling in future,
Corsair or Cooler master Double Fan RGB
cooler master masterliquid 240 rgb liquid cooler
or maybe
Corsair Hydro Series CW-9060025-WW Liquid CPU Cooler (Black)
So here is my Question and i need help with tha.
1) Does my Motherboard Support this liquid cooler?
2) also i need a cabinet like that which will support my selected spec, and liquid cooler in future.
3) alo confused in selecting Graphic card.
someone suggested me to buy
Gigabyte GeForce GTX 1060 6 GB Graphic Card:-
https://www.amazon.in/Gigabyte-Geforce-Gtx-Video-Card/dp/B01JNUO6BG
Which is better Video Card
This Gigabyte or Zotac gtx 1060 6gb (Which i mentioned in my Spec)
4) Also, did i select a Good PSU of Corsair 550W.
IF not, suggest me good PSU with minimum range.
5) Does it have any Problem, i will add 16GB ram more next year.so..
My Location is : Ahmedabad, GUJ, India.
My Spec:-
or maybe
