Discussion Need help with an RTX 3050 6GB
DAPUNISHER
Super Moderator CPU Forum Mod and Elite Member
Super Moderator
Picked it up for $140 open box from Best Buy.
I have not used an RTX card in a couple of years, and things have changed since then. I downloaded the Nvidia app and let it install the latest WHQL drivers. What is the best way to override the DLSS model in the app? Is it just a .bat file? Any other new tweaks that are useful?
It does not like PhysX in Batman Arkham City; fps and frame pacing can be poor at times. I guess it will have to be the dedicated card for that when I get a faster RTX. Performance even without it turned on is not that great. Bit surprised by that. My ARC and Radeon cards play the game smoothly.
Spidey Miles Morales is another story. 1440 DLSS balanced looks and plays really good. Even 1080 Quality DLSS looks good. I take ii I can force the DLSS 4 transform model? The only IQ issue I see is a bit of moiré. Zero sizzle or other issues. Improvement over IGTI and XeSS on other brands. Playing with 1440 high, DLSS balanced, RT reflections high on distance 7 it is smooth and enjoyable. It does not like DLSS upscaling and FSR frame gen together -
Thanks in advance for help and info.
Maybe @Golgatha can help?
I don't have that game and even if I did, I don't think I would have the patience to download it (I seriously sometimes feel like I'm too old for games now. Maybe I should just get a parrot).
One general piece of advice would be to launch this game from within the nVidia app. The nVidia app should apply optimal settings for your 3050 6GB.
I appreciate your time. :beercheers: It is an Nvidia driver issue me thinks that is causing the crash with FSRFG. My B580 works fine with it.
You use yours as a PhysX card correct?
I have the spiderman games dialed in as good as they will get. I was more interested in what kind of mods Nvidia owners are using. I have not had an RTX for a couple of years. Optiscaler, .BAT files, or what? for using DLSS in unsupported titles was my main interest. A search shows a number of solutions so I wanted to ask people I trust which is the best route.
