Please help me find the right 8 pin extension cable - 9070 xt - powercolor
boed
I have a new 9070 xt but the cables to my power supply are a little short. I have two types of 8 pin extensions and neither fit.
The ones I bought (two types) both look like this. I bought them assuming they were all alike.
Is there a specific name for the extension cables I need? I admit I've never encountered this issue before.
Should be PCIe power as opposed to CPU power, often also called 6+2 pin. The one in picture looks like it is for CPU, 4+4 pin.
Thanks - I admit, I never knew there was a difference.
Compounding the confusion, not all extension cables are compatible with all brands and models of PSU. Some use their own pin layouts.
