Balakrishna Prasad
Hello! I recently purchased all new PC components and built my first PC. I have been facing really weird issue with my ASUS STRIX RX 480 8GB @1266 MHz since purchase. After a few minutes while gaming, the whole system freezes (Sometimes with Grey screen and sometimes Black screen with buzz-sound) and requires a Hard Reboot. This happens only while gaming. I surfed all over the Internet and found many users with the similar issue but actually unsolved. Even me, I'm unsolved and can't really figure out what exactly is the problem going on. Majority of the people say that it is either the PSU problem or suggest to RMA the card. It is definitely is not the PSU problem, and no need of RMA either. By the way, I really don't do overclocking at all.
Here are the videos some guys posted with the similar exact issue I'm facing:
https://www.youtube.com/watch?v=gi2Vh9psWKI&index=4&list=LLuA9MPnkiCooZ2ENMDZD8kA
https://www.youtube.com/watch?v=vaxJHaR0Gng&index=5&list=LLuA9MPnkiCooZ2ENMDZD8kA
My PC specifications:
Intel Core i5-6500
Kingston HyperX Fury 16GB (8x2) DDR4 2133MHz
ASUS MAXIMUS VIII RANGER Motherboard
WD Caviar Blue 1TB 7200 RPM
Corsair VS650 650W Power Supply (I really don't blame my PSU, I think it's really enough to handle the GPU)
Case Coolers - Proper Airflow with 4 case fans installed
Cooler Master Hyper 103 CPU cooler
ASUS STRIX RX 480 8GB 1266 MHz (Factory Stock)
What I tried, nothing worked:
Thinking of RMA? But why other users of RX 480 experiencing the same!? I am sure there is no GPU
fault at all.
All my system components are brand new and it's just 1 week old. Again repeating, no overclocking done, done all the major steps to take care of. If I search using keywords 'RX 480 Freeze PC', I can see many forums out there pretending to be solved.
What do you pals say? Any neat help would be appreciated.
Thanks in advance.
Intel Core i5-6500
- I checked the temperatures and voltages of every component in my CPU using 'HW Monitor'. All the temps were fine. Here are the temps in 'Celsius': CPU: Min - 37c Max - 52c; GPU: Min - 45c Max - 77c; Mobo: Stays at 39c; Voltages showing: CPU VCORE: Value - 1.104V Max - 1.120V; +12V: Value - 12.288V Max - 12.384V; I find nothing odd in the monitoring. I think all these values are fine, right?
- Tried 'DDU' Tool and re-installed all the latest Drivers for AMD (17.1.2). I have also tried with oldest drivers to the newest which doesn't help.
- Some forums say that there is some bug in Windows 10 causing freezes and crashes. So, I tried playing and working with Windows 7. Nope, didn't help, same crash!
- Tried clean installation of Windows 10 and of course, I disabled 'Windows automatic driver installation settings' with the help of some sites.
- Tried maintaining GPU temps around 75c by adjusted fan speed in 'MSI Afterburner', the temps maintained good, but the issue is not the temperature.
- Tried changing Windows Power options to 'High Performance' mode from suggestions from various sites.
- Update BIOS settings and looked at any odd settings in BIOS, none looked odd (default settings).
- Ran many tests using various softwares like Prime95, MemTest, FurMark etc. None of them showed errors and freezes.
- Tried tweaking the GPU settings in 'Global WattMan' like Underclocking, Power Limit etc.
fault at all.
Thanks in advance.
