RX 550 max monitor configuration
satai
Is Radeon RX 550 2GB able to connect 5k@60Hz and an other display at the some time?
I have connected XB2779QQS via DP 1.4 and an older Dell (1920*1200) via DVI. At the moment I set XB2779QQS to 5k the image at the Dell disappeares.
If RX 550 is not enough what are the options? (I don't care if I use RX or VX.)
No solution? I supposed this is going to be easily found in the docs or spec or at least a common knowledge :-/
I just got the 550 with 4 Gigabytes of ram and an arse I'm redacted upset I what ever purchased it knowing that after a world of tanks of dated yesterday that I would have to keep my settings on low to nothing I have a son4 core w3565. 3.2gz And just purchase a w6570. 6core3.2gz . I hope with 50nmore cores it will do somewhat batter not meen 3000. To the 6000 sreezzy chip . I hope . But I think I can sand me video card back for 4gb ram .gtx1050 . 145 new. Or I cab get used amd7970 3gb RAM .316 or something bits . It 3 Smithing idk off hand but I I do no it is over 300 bits of graficks I hope wood be batter than a 550rx r9 lmk pleezz meen a lot to me that I have no Flagg in ward tanks I meen is it mee or now up dat wot it bad all setting mind low or lagg .Its their bata
Profanity is not allowed
in the tech forums.
AT Mod Usandthem
I got a x3565. 3.3Xeon 4core 12gb. 500gb hhd. 7200rpm . And a Rx 550 4gb ram. Amd video card with a27in screen. For 170$ with new rx550 in box's. And driver I have a s20 mother Bord. I have to no can it over cock with a w3565 or w6570
