JWMiddleton
UPDATE: In a few posts below will be my experience with the SATA to 6-PIN option to power a GPU that requires more that the power provided by the PCIex16 port on a Dell OptiPlex 9020 or 7020.
--------------------------------------Original Question------------------------------------
I would like to put a 120 watt TDP GPU into a Dell OptiPlex 9020 with stock 290 Watt PSU. Since it doesn't have the needed 6-pin PCIe power, I was looking at a SATA 15pin to 6pin PCI Express Card Power Cable. SATA power provides 54 watts (4.5A x 12W.) So, 54w from cable plus 75w from PCIe slot gives me 129 watts. This doesn't allow much margin. The card is not overclockable.
My question has to do which cable to get as there are 2 options: 2 SATA to 6-PIN vs 1 SATA to 6-PIN, see photo. Has anyone had any experience with either cable? Suggestions, besides another PSU.
