[Solved] Monitor goes to power saving mode (sleep) within 5 minutes of gaming
crusadehs
Happens when I try to play Overwatch, Metro LL and Witcher 3 (sometimes it makes a clicky noise when monitor goes to sleep sometimes it doesn't). Does not happen when I'm just web browsing and watching youtube videos.
Specs: i7 4770k @4.1Ghz, GTX 980Ti (110% power limit but not manually overclocked or messed with voltage), Rosewill 750W Power supply, windows 10
So far I've tried and to no avail: reinstall Nvidia GPU driver, reinstall Overwatch from my HDD to SSD, reseat the GPU and re-plug in the power cables with different configurations (8+6 pin), 3 different displayport connections with my main monitor, running HDMI connection alone on my secondary monitor, setting power settings to high performance (never turn off display & never sleep).
My 980Ti barely goes above 70C so I don't think it's overheating, but I think it is most likely something wrong with either the PSU or the GPU, since I tested both monitors that I have and same results. Any help would be appreciated..
UPDATE: Just played 50 minutes Diablo 3 RoS without a hitch. CPU usage is around 20% (2 cores) and GPU usage hovering around 50%.
Update #2: I managed to change the Overwatch setting to 1080p 60 FPS to reduce the GPU load down to about an average of 30%, and I've been playing for just over an hour without issue. So it seems that something in my system that has issue with high GPU load.
Edit: Played another hour of Overwatch @1440p 60FPS without issue, average GPU load is about 40%.
How many amps on the 5v rail is the Rosewill capable of?
With a top end video card you should have atleast 50Amps.
Its easier to test the graphics card with a a benchmark like 3dmark or unigine heaven/valley. Unigine is a smaller download so I use it. And don't rule out the mb. I had an old mb problem where where add on cards would behave in a flaky manner.
Go to control panel, power options and enable "high performance". If it still does that your GPU might be dying.
Thank you all for helping! I tested my 980ti at a friend's place and it is dead.. (probably a blown capacitor or something of the sort because it emits an unpleasant smell).
