Startup Repair couldn't repair PC Please Help I ran out of options (Solved)
wxradar12
So I tried to boot my computer up this morning and it attempted to boot and than it said, "Diagnosing Problem" and after that it said "startup repair couldn't repair PC" and gave me the option to Shut down or Advanced Option. So I wen't into advanced and I tried to look for a restore and it said "None found" So than i figured out its a drive problem that I am missing with windows I believe. (I was running Windows 10) I tried to download Windows 10 using a usb on the BIOS boot up and it said the following after attempting "The computer started using the Windows installation media. Remove the installation media and restart your computer so that Windows starts normally. Then, insert the installation media and restart the upgrade. (Do not select "Custom (advanced)" to perform an upgrade. "Custom (advanced)" installs a new copy of Windows and deletes your programs and settings.)" So I am out of options here any idea? I have back up on all my files on my laptop I just want to fix this problem asap.
