i have 2 12s in a sealed box r types they are 1000 watts rms have an Orion amp that can power these speakers it's in an SUV feel as if I'm not getting enough bass. Every time I turn up gain goes into protection mode
You're saying it doesnt get loud enough for you and the amp is going into protection mode. So you need either higher sensitivity subs or a better amp. Doesnt seem that complicated?
1. Check your wiring. Make sure nothing is being shorted. Even a single strand of speaker wire shorting will cause the amp to go into protection.
2. Make sure you're not exceeding the impedance (ohms) of each channel of the amp. Most 2 channel amps can only handle 2 ohms each. If you bridge then that usually drops to 4 ohms. Some mono sub amps can go as low as 1 ohm. Check the specs of your amp.
3. Check for correct polarity to the speakers. Reverse polarity will cause low bass output.
