petrusbroder
Elite Member
One of my computers does not start anymore. It has a Gigabyte mobo, socket 1156, with a i7-860, 8 GByte RAM. I've tested it w/o connected hard drives, with only one stick of RAM (2GBytes), GPU and Keyboard - the same symptoms as when fully equipped.
When I power up, it works OK for 2 - 3 seconds, then powers down and tries to restart.
Any guess what the problem may be? Mobo, CPU? I've inspected the mobo, don't see any broken capacitators or burned spots. PSU works perfectly, tried it in othe computer; also a brand new PSU does not change the behavior.
If it is the mobo, is it worth to get a "new" one (e.g. previously used)? Does anybody have one available for not too many USD (I pay for shipping) ...
If it is the CPU I will not replace it but use the parts for an other computer, the case; PSU, HDD, GPU, DVD-unit are all in good shape and much newer than the mobo, CPU and RAM.
The combo has worked 24/7/352 since December 2009 ... for almost 8 years, with less than 5 days rest during this whole time ... it has crunched all the BOINC-projects I've participaed in and all the Folding@Home races since 2009.
