If you're comfortable with python, pypdf should be able to handle that for you pretty quickly. Might be worth looking into if you have to do this fairly regularly.Starting a new job, and I have to copy/paste coordinates from a pdf into a spreadsheet. About 550 points, and boring as shit. There's a whole bunch I don't need, but it would be more work looking at the plans to thin them out than to just put everything in and do it in the field. I'm actually lucky the pdf is good, and it isn't just a stickyback on a set of plans. Otherwise I'd have to compute/input them manually D^:
For this project I just want to get it done, but I'll look into that going forward. Thanks!If you're comfortable with python, pypdf should be able to handle that for you pretty quickly. Might be worth looking into if you have to do this fairly regularly.
Weird seeing housing so close to the west and the mobile home park to the south.
Le sigh... This section is just an image, and I can't clicky click to select numbers. All hand entry. It isn't essential to get started on LOD, so I'm debating getting started entering it in the spreadsheet, or waiting to put it in the data collector. I still have to compute radius points for the alignment. I can do that with tools I have at home, but it's more of a hassle than doing it in the collector.I'm actually lucky the pdf is good, and it isn't just a stickyback on a set of plans.
I've played with it a tiny bit, but I *really* don't understand how it works. A bunch of years ago I was able to extract some data from county datasets the cadmonkey and boss needed, but it was only through hacky perseverance I was able to do it. It's a tool I could have some fun with, but isn't needed for work, and I don't find it fun enough to really learn.As a side note do you play with Qgis at all?
When I discovered that the layout changed it was both very beautiful and very sad - the layout of ATOT forums has changed. I'll tell you what, people are not happy about it. Not happy at all! It's poisoning their minds. Some very nasty people who changed the layout. We will fix it!SOMEONE CHANGED HOW ATOT LOOKS!
I'm confused as well.SOMEONE CHANGED HOW ATOT LOOKS!
The way I see it, the fact that they even did an update and changed stuff means there's someone in the background that didn't forget about the forum and there are still resources to keep it alive so there's that!SOMEONE CHANGED HOW ATOT LOOKS!
I'm not seeing that as a problem. Sounds good. Maybe let some get stale and crumble it in tomato soup.My cheesy herb bread is too herby. It's like eating a slice of stuffing
