Orodruin
Hello everyone.
I am using Zotac RTX2060 Mini. I have a problem with the heatsink.
I removed the thermal paste and pads of the gpu to renew it.
However, the surface that corresponds to the VRM part and that I marked in the photos is out of place.
They normally glued the part where we place the Thermal Pad to the aluminum heatsink. But when I removed the card, that part came out. What can I paste it back there with? What heat resistant would you recommend I use glue?
So I need a heat resistant adhesive that will bond metal to metal. Which adhesive should I use?
I would be very happy if you give me an idea.
