Zowie by BenQ XL2411P vs. ViewSonic XG2402
Hi to all,
as the title says and I am at the process of choosing a better display. For 1,5 years I had the BENQ XL2411 and I was quite happy with it until LCD panel broke and I got my money back.
Which of those two do you see as a better display when it comes to overall performance. The price in my country is the same. What I have read about is that the ViewSonic XG2402 has some contrast issues as described in this review.
I cannot come to a conclusion as one reviewer says ViewSonic XG2402 is far better and another one says the opposite.
Moreover, since XG2402 has build in speakers I experienced with the XG2401 model that there was slight buzzing noice in the back of the screen that I could hear and was very disturbing. Have anyone of you experienced the same? If that would be a case and there was no option in turning that off then I would definitely go for the Benq XL2411P.
Thank you all for your advice.
They look to have the same / similar specs... If you were happy with the BenQ, I don't see any harm in getting another over the ViewSonic. BenQ makes good products generally, you probably just got a dud.
