superstition
Platinum Member
I am setting up a VR-centric ITX system for a friend and wanted to try undervolting to see if I can reduce temperature under load.
I tried various reductions and ended at 1.15 (with level 2 LLC in the AsRock Gaming ITX/AC board and Corsair H90).
I've read that using the offset voltage is more optimal for power savings but I'm wondering if it's really significant enough to bother with since this setting seems to be stable and is a good amount below stock. I'm not getting noticeable droop or overshoot under Prime which is nice.
I'm not planning to overclock.
