AMD 1950x Threadripper Overheating in Propellerhead Reason 10 [Resolved]
Page 4 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
*UPDATE*
Well boys, we did it. It turns out it was as simple as someone not properly connecting the wire to the radiator. The wire is up top behind the fan somewhere and is "hard to see" so it is "easy to miss" apparently - so if anyone else has this problem - that should be one of the first things they check.
Sorry to raise the alarm bells on Propellerhead's Software! But I took it to TWO PROFESSIONAL REPAIR TECHNICIANS! THREE! IN TOTAL!
The THIRD repair technician finally caught the problem...
I just ran through my entire song Overclocked at 3.8 GHZ @ 37.25 degrees C! A TREMENDOUS DIFFERENCE! It used to slowly climb to 85, then crash.
Now to stress test with AIDA64.
I would not call them PROFESSIONAL REPAIR TECHNICIANS, but simply minimum wage idiots.
It's a credit to the heat capacitance of liquid cooling that it could operate by passing through a radiator with no airflow. All but the most massive of air coolers running without a fan would have let you know about it very quickly, and even then, all would have collapsed under any sort of Threadripper load. I'm glad you got it sorted! And thanks for letting us know what the cause ultimately was 😀
HAHA!
Thanks for all your help/ support!
This really is a great community! I will be sure to stick around and try to help others!
Given the symptoms I would guess one or both of the radiator fans. Seems like that would be so easy to detect, though, I didn't even think to mention checking for fans not spinning...
Actually, I think its the pump that was not working, thats a separate plug.
Either one would lead to the problems he mentioned. The pump not working would cause problems sooner, so I'd venture a guess it was the fans.
I am only guessing that it would be easier to miss that, than seeing no fans on the rad. That might explain why it took so long to find it. Even the user could see that (Raizor)
Yeah, I swear I heard, saw, felt the fans. I put my hand over top of the radiator many times.
*I just did it right now and its pumping out COOL air as opposed to the HEAT that I think I remember feeling before*
I ran Final Fantasy XV last night at Highest Settings at 4k and was hitting 40-60 FPS @ 30 degrees C.
Also - right now I increased my Overclocking from 3.8 GHZ @ 1.23125V to 3.9 @ 1.23125 V and 3.95 @ 1.23125. I tested it out and my song - with web browsing - steam - and other apps open was running fine. Without any errors/ crashes.
Is that a good sign for this whole "Silicone Lottery" I've been hearing about?
Ok... so I kept my SAME Voltage of 1.23125 and kicked the Clock up to 4.0 GHZ and am running Aida64 Stress Test at 100%...
54 degrees.
Guys - I have ANOTHER set of problems though it looks like. Should I start another Thread/ Post in another Forum or something? OR do you think we could handle it here?
That "Red Line" on the SSD was GREEN every time I ran this test before. The Latency was ALWAYS YELLOW for the RAM - however - it was ALWAYS performing in the 90th percentile or higher... I have no clue why any of this would change.
Is it the Voltage I'm running at now?
You should start another thread in the Memory and Storage area. Could come down to a lot of factors. I would start by making sure you have your Samsung Magician software installed, have the latest drive firmware installed (make sure you always have a backup before upgrading firmware), and the software doesn't point out any obvious faults.
It looks like your ram is currently running at very low clocks affecting your system performance. Try adjusting the memory clock.
Ok, mates, thank you. Didn't even know Samsung had software for it's SSD. Also - I don't know how to change RAM speed :/
That would make more sense if the pump wasn't working. You basically turned a full blown liquid cooler into a vapor chamber. This is an easy mistake to make. Hell I am guilty of almost tearing a build down because I forgot to hit the power switch on the PSU.
I also had an issue with the mounting bracket being a very tight fit on the threaded mounting screws. Had to really work it to get it down and in contact with the CPU heat spreader.
I too had the same problem.
Got one of these off amazon.
Mine reamer was too large for this application, but this fit the bill! and all for under 10 bucks.
https://www.amazon.com/gp/product/B074TFSS9R/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Worked Beautifully! Temps are now in high 30C at idle. Was never like that before, I suspect that who ever drilled the holes on these mounts, were off a bit. Just be careful you don't drill too much as you could end up creating a slot! LOL. Easy to do, fit's much better and I get way better cooling now, since the springs don't have to fight the threads. Slides right over the mounting screws like it was suppose to.
Hint: You don't need to remove the entire mount. As I was thinking, there is NO way I'm going to drilling shrap metal next to my case, you can actually slide the metal mounting clip off of the cooler. So, just pull it, slide out the clip, take it out to the shop, enlarge the 4 holes a bit, test fit, clean old compound, reapply thermal paste.
BOOM! enjoy the cooler temps!
I may have to give that a try.
"The wire is up top behind the fan" - are you referring to the fan connectors or is there some other separate wire for the radiator? I am interested because I have the exact same setup taichi x399, tr 1950x, enermax tr4 240 and mine does lock up due to heat when OC'd to 4.0ghz and there is heavy cpu activity. I went through all the steps in enermax's video.. https://youtu.be/Wvj8HNcJLag It does not mention any wire to the radiator, only to the fans and the pump block. Is there another wire?
what are the temps of your cpu? tr4 240 is not designed to OC a 1950x, better luck with a 360.
Also what are you doing to lock up your system? Are you running full loads 100% or just benchmarking?
Download HWiNFO64 to monitor the temps. The only power is to the pump, and the fans. Also what voltages are you using when you OC?
You need to use Ryzen master to OC and show us the temps please.
My TR runs 46c @100% load. running 3.8 all cores. 1.125 vcore. Bios is all stock
Mark is that with the 360? I ask because I'm troubleshooting an issue right now with my machine, overclocks have gotten hotter and I'm not sure if it's due to board issues or if the Enermax 360 is dying.
