Intel processors crashing Unreal engine games (and others)
Page 12 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
That's really weird. What kind of power usage causes degradation in Raptor Lake CPUs over the long term? Alder Lake was pushing 200W+ and has been for quite awhile without having these problems . . .
We don't know if it's degradation, at least not as the main cause. Buildzoid has a rant video on the subject, and one of the things he talks about is that folks who test multiple top tier K CPUs for binning will repeatedly stumble upon chips that fail to pass stability tests out of the box. That does not mean the chips are bad, it likely means that the board configuration is too aggressive for that specific CPU. It's rare, but it happens. In this case there's definitely no degradation, the CPU is brand new.
My hunch is that one can take such a "bad lemon" K CPU, shove it in a B760 board with locked CEP and conservative stock power/current limits, and it will work just fine long term. It just won't win any benchmarks.
PS: It seems I linked the wrong video above, he already has 2 videos on the subject. The first and longer one is here, but anyone looking for a "shorter" take should check out the newer one.
Builzoid is ranting on twitter about the issues.
that board is literally on the latest BIOS. Intel is really quick to patch BCLK exploits with microcode updates and gives exactly 0 <insert profane word here > about shipping functional 700USD CPUs.
EDIT: We both posted about Buildzoid seconds apart.
Simul-jam
So the reddit comment that triggered BUildzoid's second video argues that Asus/Gigabyte and to a lesser extent MSI/AsRock undervolt the CPUs using AC Loadline settings to make them perform better in benchmarks. This is done by eating into the safety margins, they are essentially undervolting after they're done overclocking out of the box.
This would indeed also explain why "it feels" like the CPUs are degrading, because any aging effect on the CPU could make it pass the threshold to instability, since the safety margins were sacrificed to justify a price premium on those fancy new board and CPU. It could also be a matter of seasons, you buy the CPU in the winter and it's stable, summer comes with higher temps and... "not enough video memory"! 😎
Here are are some quotes to take into consideration, emphasis mine:
All CPUs degrade over time but that's why their fused VF curves have a sizeable buffer to account for derating.
ASUS/Gigabyte and (from what I observed) to a lesser extent MSI/Asrock Z-boards set an AC load line (AC_LL) & LLC level that undershoots the VF curve significantly under load and eat into this buffer. Because AC_LL undervolts increase in size as CPU amps increase, unlimited power results in more undervolting relative to the VF curve.
Alder Lake and Raptor Lake CPUs also have a clock stretch feature (IA CEP) to account for Vcore undershoots, but due to the aforementioned AC_LL undervolt causing it to trigger constantly under load, it is disabled by default on the Z-series boards I have tried.
Regrading CEP, I should mention it was enabled by default on my MSI Z690 & 12700K combo, so this varies. Let's keep reading:
While the spec says AC_LL == DC_LL == LLC slope, in practice motherboard vendors undervolt by doing AC_LL << DC_LL* == LLC slope. The CPU does not request enough voltage to counter the LLC Vdroop so Vcore falls below the programmed VF curve that would be followed if AC_LL == LLC.
On a freshly reset ASUS Strix Z790-H with MCE off, here are the values I see:
Setting Value
AC_LL 0.5
DC_LL 1.1
LLC 1.1 (LLC3)
VID 55x idle 1.30V
VID 54-55x CB24 1.26V
VF 54x 1.289V
Uh oh, I'm 30mV short out of the box at 253W for 54x and well over 50mV short of 55x.
ASUS LLC6 would be the closest to Intel spec for AC_LL 0.5, and that is a little better than AC_LL 1.1 + LLC3 in their Baseline profile IMO since it won't boost idle turbo VID to >>1.6V...
*DC_LL is only used by the CPU to compute post-droop VID for power measurement, AC_LL + motherboard LLC are the two Vcore levers that affect Vcore in an unthrottled state.
Well okay, but again Alder Lake didn't have that problem either. Though if it is as you say and the mobo OEMs have started effectively undervolting Intel CPUs @ "stock" while not doing so on Alder Lake CPUs, then that might explain things a bit.
Looks like Intel issued a statement on the situation:
Intel blaming AIBs while they have known about this for many years, and even used the high-end boards with extreme settings in their 1st party benchmarks 🙄
In Computerbase review they didnt specify that the 14900KS was set at 253W contrary to other CPUs, and for a reason since it was stock set at unlimited power, as in Intels s recomendation.
The CB is simply set up for 253W PL2, which is only about 36,000-37,000 according to the ASUS“ intel baseline”.
View attachment 97961View attachment 97963
Why post the CB score without the power, and yet it s also measured at Computerbase for Cinebench.?.
Because you know that you are lying, full system power in Cinebench for the stock 14900KS is 522W, there s no other numbers for this CPU, and Computerbase always do tests at stock, they have a separate article for overclocking, btw CPU package power in Prime 95 is 355W at stock, about the same CPU power as in Cinebench.
ADL was in a better spot at launch relative to both prior gen and the competition. We could also argue It was also a new platform, with a learning curve attached for the board makers and a massive workload to get stable systems at launch, not to mention proper XMP support for both DDR4 & DDR5. Heck, Gigabyte was so busy theyr forgot to add NVME support on their launch UEFI version 🙂 The landscape changed drastically for RPL and then the refresh, both in terms of pressure to deliver perfomance and in terms of time for agressive tunning. That's my impression anyway.
No real arguments there, though there were certain lines they (they being Intel and the mobo OEMs) knew they shouldn't cross, but eventually they did it anyway.
Is that a typo? 522W? Or did you mean 322W?
What's a few more watts? 🙂
T
TPU do measure at the motherboard's 12V connector:
All power measurements on this page are based on a physical measurement of the voltage, current and power flowing through the 12-pin CPU power connector(s), which makes them "CPU only," not "full system." We're not using the software sensors inside the processor, as these can be quite inaccurate and will vary between manufacturers.
Whereas Computerbase do full system (and later package power using the internal sensors), although using Prime95 not Cinebench R20 so not directly comparable. For Prime95 using the CPU sensor they get:
355W, which is actually more than those big Threadrippers although since Prime95 is not something they benchmark it is hard to see what that means.
We do know that for Cinebench R20, the 7980X is way over twice as efficient (scoring 37,070 using 505W vs the 14900KS scoring 15,629 while using 522W). And CPUs with a similar score to the 14900KS like 7950X use 329W, and a bit behind that a 7950X3D uses 233W (all whole system measurements).
Wow. Insane data point. Someone somewhere (I think it was a github thread) was bemoaning buying the 14600K and saying that 180W isn't even enough to feed the 6 P-cores properly, let alone the additional E-cores. If that's true, what has Intel created, seriously? They really must badly want the poles to melt!
HUB video cites Cutress from an AT interview:
999w is IN SPEC.
Interview from 2019:
Yep, the tl;dw is that Intel has told MB makers and reviewers for the past several years that unlimited power settings are still considered in spec. So Intel has not just ignored this behavior by MB makers but condoned it, which was obvious to those willing to see it, but now there are receipts as well.
To boot the sad joke that intel is becoming, I was watching a stream earlier with a guy who kept having insane throttling on playing...Factorio. Not a Megabase either.
Turns out that he had a 13900H in a thin ASUS Vivobook.
The CPU was at 88°C with 40% usage.
Brah-voh, ASUS.
