Nah, those are the one size fits all ladders that you distribute around the room. Beats the hell outa standing on the shopvac to reach those really tall spots 😉Look like 40 gallons of paint sitting on the floor. That's some seriously shitty coverage.
Those have been around for a year or two. Handy gadget if it's accurate.
SUPER cool: Sketch to Render timelapse!
1. Use AI to generate an architectural sketch
2. Use AI to generate a finished render
3. Use AI to generate a timelapse using start & end frames!
Odd that the mid section doors are wider than the lower doors but the cabinet is the same size.
Other than the AI stroking out on the doors, and forgetting the hinges, it's not a bad setup. I'd have done pullouts in the mid section as well.
Also just noticed that it appears that the fridge doors won't open far enough to access any pull out's.
Hyperscape Capture:
* Hyperscape lets you capture your real-world space in just minutes, then creates an immersive, true-to-life digital replica that you can visit from anywhere.Meta Horizon Hyperscape Capture (Beta) on Meta Quest | Quest VR games | Meta Store (en-gb)
Hyperscape lets you capture your real-world space in just a few minutes, then creates an immersive, true-to-life digital replica that you can visit from anywhere.www.meta.com
* Bring your real-world spaces to VR: Hyperscape lets anyone create digital replicas of their physical spaces, with high visual quality and realism.
* Last year we showed the world's highest quality Gaussian Splatting, and the first time GS was viewable in VR.
* Now, capture your own Hyperscapes, directly from your Quest headset in only 5 minutes of walking around.
