Question RAIDXpert2 LECACY array gone! What i should do?
St0RM53
So big story short, i built a PC a few years ago and got a 14tb HDD to go with it. Since then i wanted to buy another one after i had the funds to make a RAID 1 array for redundancy.
I got the 2nd drive a few days ago and today i've installed it. Since i don't have another big drive to copy the data to temporarily in order to create the array and then copy it back i came up with a plan that should work in theory:
1) Install the 2nd drive and create a "RAIDable" array that will allow me to make a real array after i add at least one more drive
2) Copy the data from 1st drive to this array of 2nd drive
3) Add the 1st drive to the array to make it RAID 1, losing the data of 1st drive in the process
When i've installed the 2nd drive today i removed all the other ones. Inside the bios using the RAID menu it wouldn't give me the option to create an array since if i used the option to initialize the drive it didn't do anything. So there was no "RAIDable" option to be found anywhere.
So i decided to check what i can do with the software instead. At this time i put the 1st drive back in too.
Inside the RAIDxpert 2 software 1st time i've opened it it showed 2 arrays. One with the 1st drive shown as LECACY and one with the 2nd drive as VOLUME.
And here where my problem occurred. I clicked to initialize the 1st drive and it automatically deleted the LECACY array without asking and there is no option to bring it back. Now i have no access to my data.
Here is a screenshot:
Reverting back to AHCI with the 1st drive only it shows it totally messed up: It was a single partition with about 7.5TB of data..
What i can do now?
I found this similar issue here: https://socialtechwork.com/threads/accidental-hdd-array-deletion-raidxpert-array-recovery.2572332/
My guess is to create a new array, and make it RAID1 from this step but click "leave existing data"? Then how do i recover them?
Any help with be really appreciated. My system is based on AMD X570 chipset.
Kind regards
Here's a log of so far:
Code:
***Create Log file for RAIDXpert2 Start: 5/06/2021 1:51:02 PM   ***
5/06/2021 1:51:02 PM   RaidConsole2 Log Start
5/06/2021 1:51:02 PM   Dumping current configuration to log file.
5/06/2021 1:51:02 PM   BufferSize: 1685
CO: 1 GE: 1 NM: //./Core1/Route0/Device0 BN: 9.3.0-00206
CD: 0 CN: VSTOR CSN: 0x000040004b008590 KE: 00000000000000000000000000000000 BB: NONE MX: 0x0000000000000000
NP: 8 VI: 0x8590 DI: 0x1022 SVI: 0xf803 SDI: 0xffff ID: 0x0000859010220000 OVI: 0x0000 ODI: 0x0000 LOC: 0x00000000
CD: 1 CN: AMD-RAID CSN: 0x000000004b2a1d00 KE: 00000000000000000000000000000000 BB: NONE MX: 0x0000000000000000
NP: 1 VI: 0x1022 DI: 0x7916 SVI: 0x1022 SDI: 0x7901 ID: 0x0000000000000000 OVI: 0x0000 ODI: 0x0000 LOC: 0x00000000
CD: 2 CN: AMD-RAID CSN: 0x000000004b2a1d01 KE: 00000000000000000000000000000000 BB: NONE MX: 0x0000000000000000
NP: 5 VI: 0x1022 DI: 0x7916 SVI: 0x1022 SDI: 0x7901 ID: 0x0000000000000000 OVI: 0x0000 ODI: 0x0000 LOC: 0x00000000
PD: 0 TY: Core ST: Online ID: 0x0000859010220000 NM: //./Core1/Route0/Device65535
PD: 1 TY: Unknown ST: Online ID: 0x0e0976581a4605c0 NM: //./Core1/Route1/Device0  CD: 1 CH: 4 RT: 1 HD: 0 FE: 0x21ed0018 GS: N SI: 0x000000065de00000 LS: 0x0000000000000000 TS: 0x0000000000000000 MO: ^WDC  WUH721414ALE6L4                    ^ SN: ^Y5JUXXTC____________^ FW: LDGNW240 PT: 0x00200304
VI: NONE
LD: 0 ST: NORMAL ID: 0x0e0976581a4605c0 NM: //./Core1/Route0/Device1  OSN: NONE RT: 0 HD: 1 SI: 0x000000065de00000 1ST: 1 2ND: 1 CA: NC CTS: 1 TY: LEGACY GE: 0x00000000 TPST: 0x0000000000000000 TPSI: 0 TPC: 0.0000 TP: 0 TTY: NOT_ACTIVE TST: NOT_ACTIVE DS: 0 PRE: 0 AT: 0x0000 RC: 0 CF: 0x0000000000000000 CT: 0x0000000000000000 DP: NONE
LE: 0 RT: 1 HD: 0 ID: 0x0e0976581a4605c0 SO: 0x0000000000000000 SS: 0x000000065de00000 DO: 0x0000000000000000 DS: 0x000000065de00000 ER: NoError
PA: 0 RT: 0 HD: 65535 ID: 0x0000859010220000
5/06/2021 1:51:02 PM  - Initialized messages space, starting message logging.
5/06/2021 1:51:02 PM  - A new unknown device was inserted on controller 1 channel 4.
5/06/2021 1:51:12 PM   RaidConsole2 Log Start
5/06/2021 1:51:12 PM   Dumping current configuration to log file.
5/06/2021 1:51:12 PM   BufferSize: 1685
VI: NONE
5/06/2021 1:51:12 PM  - Initialized messages space, starting message logging.
5/06/2021 1:51:12 PM  - A new unknown device was inserted on controller 1 channel 4.
5/06/2021 1:51:52 PM  - A user request has set identify state for controller 1, slot 4.
5/06/2021 1:51:56 PM  - A user request has cleared identify state for controller 1, slot 4.
5/06/2021 1:52:03 PM  - Drive Initialized on controller 1 channel 4.
5/06/2021 1:52:03 PM  - Array 1 has been deleted.
5/06/2021 1:52:54 PM  - Drive assigned as global spare on controller 1 channel 4.
5/06/2021 1:53:41 PM  - A create task has been initiated for Array 1.
5/06/2021 1:53:41 PM  - A create task has completed for Array 1.
5/06/2021 4:01:06 PM   RaidConsole2 Log Start
5/06/2021 4:01:06 PM   Dumping current configuration to log file.
5/06/2021 4:01:06 PM   BufferSize: 2539
CO: 1 GE: 5 NM: //./Core1/Route0/Device0 BN: 9.3.0-00206
NP: 8 VI: 0x8590 DI: 0x1022 SVI: 0xf802 SDI: 0xffff ID: 0x0000859010220000 OVI: 0x0000 ODI: 0x0000 LOC: 0x00000000
NP: 6 VI: 0x1022 DI: 0x7916 SVI: 0x1022 SDI: 0x7901 ID: 0x0000000000000000 OVI: 0x0000 ODI: 0x0000 LOC: 0x00000000
PD: 1 TY: Disk ST: Online ID: 0x0e0976581a4605c0 NM: //./Core1/Route1/Device0  CD: 1 CH: 4 RT: 1 HD: 0 FE: 0x21ed001c GS: Y SI: 0x000000065de00000 LS: 0x0000000000000000 TS: 0x0000000000000000 MO: ^WDC  WUH721414ALE6L4                    ^ SN: ^Y5JUXXTC____________^ FW: LDGNW240 PT: 0x00200304
VI: NONE
PD: 2 TY: Legacy ST: Online ID: 0x722e1bf848e8413f NM: //./Core1/Route1/Device1  CD: 1 CH: 5 RT: 1 HD: 1 FE: 0x21ed0018 GS: N SI: 0x000000065de00000 LS: 0x0000000000000000 TS: 0x0000000000000000 MO: ^WDC  WUH721414ALE6L4                    ^ SN: ^9JHLSXKT____________^ FW: LDGNW07G PT: 0x00200304
VI: NONE
LD: 0 ST: NORMAL ID: 0x14df0062277f01a2 NM: //./Core1/Route0/Device1  OSN: NONE RT: 0 HD: 1 SI: 0x000000065dcfb000 1ST: 1 2ND: 1 CA: RW CTS: 1 TY: VOLUME GE: 0x00000003 TPST: 0x0000000000000000 TPSI: 0 TPC: 0.0000 TP: 1 TTY: NOT_ACTIVE TST: NOT_ACTIVE DS: 0 PRE: 0 AT: 0x0000 RC: 0 CF: 0x0000000000000000 CT: 0x0000000000000000 DP: ^5/06/2021 1:53:36 PM^
LE: 0 RT: 1 HD: 0 ID: 0x0e0976581a4605c0 SO: 0x0000000000100000 SS: 0x000000065dd00000 DO: 0x0000000000105000 DS: 0x000000065dcfb000 ER: NoError
LD: 1 ST: NORMAL ID: 0x722e1bf848e8413f NM: //./Core1/Route0/Device2  OSN: NONE RT: 0 HD: 2 SI: 0x000000065de00000 1ST: 1 2ND: 1 CA: NC CTS: 1 TY: LEGACY GE: 0x00000000 TPST: 0x0000000000000000 TPSI: 0 TPC: 0.0000 TP: 0 TTY: NOT_ACTIVE TST: NOT_ACTIVE DS: 0 PRE: 0 AT: 0x0000 RC: 0 CF: 0x0000000000000000 CT: 0x0000000000000000 DP: NONE
LE: 0 RT: 1 HD: 1 ID: 0x722e1bf848e8413f SO: 0x0000000000000000 SS: 0x000000065de00000 DO: 0x0000000000000000 DS: 0x000000065de00000 ER: NoError
5/06/2021 4:01:06 PM  - Initialized messages space, starting message logging.
5/06/2021 4:01:38 PM   RaidConsole2 Log Start
5/06/2021 4:01:38 PM   Dumping current configuration to log file.
5/06/2021 4:01:38 PM   BufferSize: 2539
VI: NONE
VI: NONE
5/06/2021 4:01:38 PM  - Initialized messages space, starting message logging.
5/06/2021 4:06:36 PM  - Array 1 has been deleted.
5/06/2021 4:07:22 PM  - Drive Initialized on controller 1 channel 5.
5/06/2021 4:07:22 PM  - Array 2 has been deleted.
5/06/2021 4:08:55 PM  - Core rescan command received.
5/06/2021 4:09:05 PM  - Drive Initialized on controller 1 channel 5.
5/06/2021 4:11:52 PM  - A create task has been initiated for Array 1.
5/06/2021 4:11:52 PM  - A create task has completed for Array 1.
5/06/2021 4:12:36 PM  - Array 1 has been deleted.
5/06/2021 5:41:13 PM   RaidConsole2 Log Start
5/06/2021 5:41:13 PM   Dumping current configuration to log file.
5/06/2021 5:41:13 PM   BufferSize: 1459
CO: 1 GE: 12 NM: //./Core1/Route0/Device0 BN: 9.3.0-00206
NP: 8 VI: 0x8590 DI: 0x1022 SVI: 0xf807 SDI: 0xffff ID: 0x0000859010220000 OVI: 0x0000 ODI: 0x0000 LOC: 0x00000000
PD: 1 TY: Disk ST: Online ID: 0x0e0976581a4605c0 NM: //./Core1/Route1/Device0  CD: 1 CH: 4 RT: 1 HD: 0 FE: 0x21ed001c GS: Y SI: 0x000000065de00000 LS: 0x000000065dd00000 TS: 0x000000065dd00000 MO: ^WDC  WUH721414ALE6L4                    ^ SN: ^Y5JUXXTC____________^ FW: LDGNW240 PT: 0x00200304
VI: NONE
PD: 2 TY: Disk ST: Online ID: 0x722e1bf848e8413f NM: //./Core1/Route1/Device1  CD: 1 CH: 5 RT: 1 HD: 1 FE: 0x21ed001c GS: N SI: 0x000000065de00000 LS: 0x000000065dd00000 TS: 0x000000065dd00000 MO: ^WDC  WUH721414ALE6L4                    ^ SN: ^9JHLSXKT____________^ FW: LDGNW07G PT: 0x00200304
VI: NONE
5/06/2021 5:41:13 PM  - Initialized messages space, starting message logging.
Fixed with DMDE if anyone is wondering in the end. It was able to recover the partition with complete file structure unlike other programs.
