LP6-10667@288bit would still give 480 GB/s
I think that's at 14.4 and not 10.7. (12 channel LPDDR6)
Good point. With LPDDR6 you could use a narrower than full-spec memory bus width.LP6-10667 offers higher bandwidth per channel (equal to hypothetical 16 GT/s LP5X), probably needs less voltage, and will be produced by all 3 memory manufacturers, so probably be cheaper per GB.
So even cutting the interface of AT3 to 75% width and go with 24GB LP6-10667@288bit might still be a better overall solution than 16GB of this "Ultra-Pro" (probably also Ultra-expensive) Samsung-only LP5X-12700.
LP6-10667@288bit would still give 480 GB/s, and 24GB has less risk of the PCIe-interface ever becoming a bottleneck.
Full config AT3 will likely perform around 9070 and has only 8x PCIe, so putting only 16GB on it may actually be risky.
If you do not reduce the asset size in DRAM, you do not save DRAM bandwidth.Are we sure it works that way?
We've had DeltaColorCompression and internal compression on GPUs with ongoing improvements for over a decade, but it never really reduced VRAM capacity requirements in any noticeable way, only bandwidth efficiency.
The only way it could reduce capacity needs would be if data is stored compressed even in VRAM.
You also need to have a HW accelerated compressor. If you modify data and want to write it back to higher level caches or DRAM you need to compress it.That's what AMD implies will happen - decompression is a lot quicker than (good) compression, so doing compression once when placing asset in memory makes sense.
10.7 Gbps are correct. LPDDR6 is 1.5x wider than LPDDR5(X). With 14.4 Gbps at 384bit (256bit with LPDDR5) you would get 864 GB/s brutto (net is less due to encoding overheads).I think that's at 14.4 and not 10.7. (12 channel LPDDR6)
No?With LPDDR6 you could use a narrower than full-spec memory bus width.
those are mobile APUs.Maybe AMD would just cancel if that ends up happening and ship the GDDR7 parts only.
AT2 is 70CU/35WGP(old).We don't know yet if desktop AT2 will get more than the 64 active CUs the leaked slide from MLID suggested, in that case it'd only be 33% more CUs.
Sure you can. Not by reducing the width of a channel, but by simply not using all channels. The same thing gets done on salvaged GPUs since ages 😉The comboPHY is very much fixed-width.
72 CU makes more sense to me. 24 per SE. Or more accuratly 36 / 12 CU in RDNA5 terms.AT2 is 70CU/35WGP(old).
4SE/8SA configured in 4/5, 4/5, 4/5, 4/4 (USR PHY is in the way presumably).
Config triggers me very much but BOM savings are vital in high volume parts.
GPUs use a heavily segmented memory shoreline.Sure you can. Not by reducing the width of a channel, but by simply not using all channels. The same thing gets done on salvaged GPUs since ages 😉
Can be all kinds of things:Assumed it had an impact due to poor 9070 -> 9070XT perf scaling is in raster games. ~12% at 4K according to TPU. That's only half of ~25% compute gain (based on TPU avg. game clock).
RT games and blender show bigger increases but still only ~15% avg and ~18% respectively.
Guess the issue is somewhere else.
- 5090 scaled far higherCan be all kinds of things:
- slight CPU / driver overhead limitations
- slight command processor limitations
- Primitive / geometry throughput (tied to SE count)
- L1/L2/L3/mem bw/capacity holding back the XT a bit more, the latter might've needed GDDR7 to fully stretch its legs
- TPU's game selection is a bit meh
Clock adjusted 9060XT -> 9070XT falls short by only ~5%. +90% TFLOP/FPS scaling at 4K.Perf scaling of adding CUs/SMs has been at only ~60-75% since forever.
Factor in clockspeed as well. Still nowhere near 25%.TPU had higher averages for RT as well.Also, according to computerbase.de, the 9070XT is actually 14% faster than the 9070 at 4K (even 16% in RT), with only ~14.3% more CUs.
Yeah NVIDIA has serious problems with core scaling.For comparison, the 5080 is only 15% faster than the 5070Ti in the same test (only 12% in RT), despite 20% more SM, 33% more L2 and slightly faster VRAM vs the latter.
But below 4K it scaled worse than any GPU before in terms of real-world uplift vs. paper advantage, and even at 4K the scaling isn't always as good as it should be in theory.- 5090 scaled far higher
That's not really an apples-to-apples comparison at 4K.Clock adjusted 9060XT -> 9070XT falls short by only ~5%. +90% TFLOP/FPS scaling at 4K.
I was referring to SE scaling (4090/5090 perf/SM deterioration), but yes assuming same frontend/backend and clocks scaling won't be perfect.RDNA5 might improve the scaling, but I think it'll only be a little better, it won't magically result in 10% more perf/clk with 10% more CUs.
256 for both but RDNA5 has much fewer dual-issue restrictions.
who cares about NV shill opinion on gfx13Digital Foundry's take on is RDNA 5 being overhyped
One of the best signs is that major console platforms have promised to use RDNA5 for their next-generation hardware. That choice shows a lot of faith in the underlying infrastructure and is a big commitment. From our point of view, this alone suggests that RDNA 5 will be able to handle tough long-term needs.
AMD RDNA 5 Architecture: What the Current Information Really Suggests | NoobFeed
There has been talk about whether AMD's RDNA5 design is being praised too much. People are often afraid of what might happen if new AMD GPUs get too much att...www.noobfeed.com
Yeah they've done problematic coverage before but recent 70 series vid is practically a MFG + 5070 advert.who cares about NV shill opinion on gfx13
I think both consoles using RDNA 5 is exciting. this is as big as RDNA 2It wouldn't be an AMD discussion if fans weren't overhyping the next generation.
Even Blackwell and Arrow Lake managed to not meet expectations. It's not just an AMD "fan" feature anymore. But they're still the best at it here.It wouldn't be an AMD discussion if fans weren't overhyping the next generation.
Everybody is shilling for Intels Panther lake It’s such an average product.Digital Foundry is right now hyping Intel's current GPU tech and chip.
In a video that will release soon they can Panther Lake at 30w is better than the Series S.
AMD better watch out.
80W stxH was better than PS5 so whatever.In a video that will release soon they can Panther Lake at 30w is better than the Series S.
Good BL.Everybody is shilling for Intels Panther lake It’s such an average product.
It's not that they hate AMD; it's just that them (especially Battaglia) love NV so much they just do infinite NV shill pieces every (even the smallest) product launch.DF hates AMD. Well known Nvidia shills.
