balloonshark
Thermalright Royal Knight 120 SE CPU Air Cooler with 6 Heat Pipes Dual Towers Cooler with Dual PWM Fans at 1500RPM Speed. Desktop Cooler for Intel 1700/1851/115X/1200,AMD:AM4/AM5
Not as good as the Peerless Assassin which has higher rpm fans.
Amazon.com: Thermalright Royal Knight 120 SE CPU Air Cooler,6 Heat Pipes Dual Towers Cooler,with Dual PWM Fans,1500RPM Speed,Desktop Cooler for Intel 1700/1851/115X/1200,AMD:AM4/AM5 : Electronics
Buy Thermalright Royal Knight 120 SE CPU Air Cooler,6 Heat Pipes Dual Towers Cooler,with Dual PWM Fans,1500RPM Speed,Desktop Cooler for Intel 1700/1851/115X/1200,AMD:AM4/AM5: CPU Cooling Fans - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
About this item
- [CPU Cooling] The CPU cooler is a double-tower dual-fan cooler, which adopts an anodic frosted top cover + fully electroplated 6 heat pipes and Seiko micro-carved reflow soldering copper bottom process, combined with a 12cm high-performance blackened fan, which can give full play to the heat dissipation effect of the CPU cooler stably.
- [Doesn't block RAM] CPU cooler leaves space for RAM, no matter how high the RAM is, it doesn't block the light output of the RAM, and there is no need to raise the front fan, thanks to the matching fans, the middle fan of the cooler is a standard 12cm cpu fan, and the front fan is a thinner 12cm fan, the thinner pc fan has a high RPM of 1800RPM, and the high airflow makes it easier to dissipate heat.
- [Twin Tower Radiator Specifications] Model: Royal Knight 120 SE, Size: 122*114*155mm(4.8*4.49*6.1inch), Heat Dissipation Material: Aluminum + Copper, All Aluminum Fins of the Main Tower, which can bring the maximum heat dissipation area, and the S-FDB bearings attached to the dual fans have a long service life to ensure the service life of air cooling and heat dissipation.
- [Dual fans with temperature control] The dual fans attached to the heat dissipation are TL-C12B V2 and TL-C12015B, with fan parameters of 120 * 120 * 25mm/120 * 120 * 15mm, speed of 1500RPM+10%/1800RPM+10%, air pressure of 1.53/1.24MM H2O, air volume of 66.17/59CFM, operating noise<25.6/26.1DB (A), fan interface: 4PIN PWM, voltage: DC 12V; High performance fans combined with efficient cooling of the main tower provide you with high-quality cooling products with care.
- [Wide compatibility] The cpu cooling is compatible with AMD and Intel platform slots: AM4/AM5; Intel LGA1851/1700/1150/1151/1155/1156/1200, the cooler comes with corresponding mounting grommets for easy installation, which can be installed according to the instruction manual or the installation video (Note: For AMD installation, you need to use the original motherboard backplane for installation)
