Ways to clean up pollution and live in a good climate.
Page 4 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
New updates about the e-REX and REX-b engine from the company INNengine.
These are new Internal Combustion Engines that are very lightweight, high efficiency and yet deliver a lot of power.
See post#13 for background information.
And the youtube channel from INNengine :
How Solar inverters in the Netherlands fail Electromagnetic Interference Compliance and are easy to cyber hack...
When you buy solar panels, you are not finished. You have to buy a solar inverter as well. An solar inverter turns the DC voltage from the solar panels into 230V AC typical @ 50 Hz (If you live in the Netherlands and other European countries).
Those inverters are as it turns out , not always as reliable as they seem.
Radiated emission and radiated immunity as wel conducted emissions and conducted immunity, all 4 parts of the EMC ElectroMagnetic Compatibility Compliance...
it means that the inverter can disturb the surroundings through radiation or conductive through cables or be disturbed and stop functioning properly.
Often these inverters contain a means of digital communication to display produced power , through wireless like wifi or wired through a network CAT cable ethernet connection.
It seems that a lot of the solarinverters are not hacking proof as well and sensitive to DDoS attacks...
Smal excerpt from text :
Dutch regulator warns of EMC issues, hacking risks for solar inverters​
Most solar inverters in the Netherlands fail electromagnetic compatibility (EMC) requirements, posing interference risks and raising the threat of hacking, says the National Inspectorate for Digital Infrastructure (RDI).
RDI published a report this week stating that most solar inverters in the country do not meet its EMC requirements. Solar inverters in the Netherlands pose risks of interference and hacking, it warned.
RDI's investigation reveals non-compliance of inverters from nine manufacturers, posing risks of interference and hacking. While all inverters meet minimum cybersecurity standards, they could be easily hacked and used for distributed denial-of-service (DDoS) attacks, said RDI.
Inverter manufacturers have a legal obligation to prevent the sale of disruptive products. Malfunctions related to electromagnetic compatibility have significantly increased in recent years, likely due to the growing number of PV installations, with 113 reports between 2020 and 2022, said RDI.
The Swedish Electrical Safety Agency conducted a similar investigation in 2021.
That is also an idea, to reduce CO2 emissions , we could use natures CO2 scrubbers. These cyano bacteria capture CO2 at a very high rate.
This bacteria could help us with developing better and faster CO2 scrubbers. Turning CO2 intho alkanes like hydrocarbons again.
See post #378 from the "Phage , the virus that cures "thread
Small excerpt from text , from the bbc website :
The island of Vulcano is surrounded by underwater hydrothermal vents, which are rich sources of CO2. These vents are located in shallow water, which means they are exposed to sunlight (unlike vents in the deep ocean). All this has created the perfect environment for the evolution of microbes that use CO2 as a food source.
The microbes found here in September 2022 are "hyper-efficient at consuming CO2 through photosynthesis", says Braden Tierney, a data scientist focusing on microbiology at Weill Cornell Medical College and Harvard Medical School, and executive director of the Two Frontiers Project, which led the research. The project was funded by US biotechnology company Seed Health, which employs Tierney as a consultant.
Together with a team of researchers from Harvard and Cornell universities in the US and the University of Palermo in Sicily, and with help from the Vulcano community, Tierney isolated a microbe that converted CO2 into biomass faster than other known cyanobacteria. A study outlining the results will be published later this year.
Getty Images
Cyanobacteria are a type of bacteria that use photosynthesis to obtain energy, capturing carbon in the process, and the new strain is "one of the fastest growing cyanobacteria… ever reported", says Tierney. He describes cyanobacteria as "nature's little alchemists" as they absorb large amounts of CO2 and can convert it into useful resources, such as fuels or biodegradable plastics.
"Early data showed [this new strain] generated 22% more biomass than the other fastest growing strains out there," says Tierney. As it grows denser and heavier, the microbe sinks in the water, which helps it sequester the CO2 it absorbs, he says.
PFAS are a real problem. However, good scientists and students have found a way to do a pretty good job at isolating PFAS from wastewater. To in the end have clean wasterwater and accumulate PFAS material to process it further. Maybe even recycling PFAS.
TU Delft (Technical University Delft, in the Netherlands) has found a cheap and good way to remove PFAS from water, by using foam created by blowing airbubbles in the water, simply said.
Small (translated) excerpt form text :
TU Delft has developed an innovative method to remove PFAS (per- and polyfluoroalkyl substances) from wastewater using foam.
This technique, known as foam fractionation, utilizes the unique physicochemical properties of foam to concentrate and remove PFAS from water treatment systems.
The process is both cost-effective and applicable to existing infrastructures, making it a promising solution to the PFAS problem.
Foam fractionation is a separation technique that takes advantage of the low solubility of PFAS in water and their affinity for air-water interfaces. By injecting air into the water, foam is created in which PFAS molecules concentrate.
This foam can then be removed, removing PFAS from the water. The technique has proven effective for a wide range of PFAS compounds and can be integrated into existing water treatment systems without major modifications.
Advantages
  • Integration into existing systems: The foam fractionation technique can be added to existing water treatment plants without the need for major infrastructure modifications.
  • Cost-effective: The method uses simple equipment and materials, keeping operational costs low.
  • Broad applicability: Effective for various PFAS compounds, including the persistent short-chain PFAS.
  • Environmental impact: Reduces PFAS concentrations in surface waters, contributing to the protection of ecosystems and drinking water supplies.
Read it here :
Dutch version :
Translated to English page :
For background information about PFAS , PFOA and C8 ; See these posts from this thread :
post#11
post#12
post#62
post#63
post#71
and post#74
Methane is the primary component in biogas or natural gas. Methane is produced in nature by methanogens , a family of bacteria that as part of their metabolism produce methane. Methane has the chemical formale CH4.
Most of these bacteria live in shallow rivers, marshes, lakes and the oceans. But also in the stomach of ruminants and even in the digestive systems of most higher lifeforms on Earth, like for example mammals.
Methane can burn cleaner than for example diesel or gasoline. Volvo trucks has introduced a 500hp transport truck that runs on liqified natural gas, or liquified biogas. Which is in essence of course the same product , only the means of producing methane differs.
Engines:
This is good news. But now it is waiting for the opposing piston engines to be further developed and be used in transport trucks to increase total efficiency of the biogas powered truck.
For information about (double) opposing piston engines see post# 13 and post#76 :
post# 13:
post#76 :
Volvo trucks:
Small excerpt from website text:
Five years ago, Volvo Trucks launched its trucks that can run on liquified biogas, often called bio-LNG, which is a renewable fuel that can be produced from many types of organic waste, including food scraps. The fuel can reduce CO2 emissions by up to 100%.
“Biogas is a great complement to electric transports, helping hauliers with their sustainability ambitions and aims towards climate neutral transports,” says Daniel Bergstrand, product manager for gas-powered trucks at Volvo Trucks.
The gas-powered trucks, the Volvo FH and FM are getting a new power level of 500 hp, joining the previous 420 and 460 hp engines. The gas engines also get major technical upgrades that makes them up to 4% more fuel efficient**, which together with a new 10% larger gas tank, contributes to a longer range.
“Our efficient gas-powered trucks have a performance comparable to their diesel equivalents. Fueling up is almost as fast as a diesel truck and the growing network of more than 600 fuel stations for both bio-LNG and LNG in Europe makes them ideal for long-haul transports,” explains Daniel Bergstrand.
and
No single solution can solve climate change
The strengthened gas-powered line up fits well with Volvo Trucks three-path strategic roadmap to reach zero emissions: battery electric trucks, fuel cell trucks and combustion engines that run on renewable fuels like biogas, HVO or even green hydrogen.
“Several technical solutions are needed because the availability of energy and fuel infrastructure differs greatly between countries and regions, and also because the requirements for each transport assignment can vary,” comments Daniel Bergstrand.
Massive plans to replace fossil LNG with bio-LNG in Europe
European production of bio-LNG is expected to ramp up quickly to shift away from the use of fossil LNG. The EU Commission has put forward a plan called REPower EU, where the focus is on creating greatly increased domestic production capacity for different kinds of energy. The plan is to boost annual biogas production ten times by 2030* and the sector has already started a rapid growth phase. Also outside of Europe the potential for biogas is gaining interest.
and
Facts about liquified gas:
  • Bio-LNG (also called LBG) is a renewable fuel that is liquid biogas (biomethane). Any organic waste can be digested to produce biogas, for example sludge from treatment plants, food waste, manure and other residual products.
  • LNG (Liquified Natural Gas) is a fossil gas (methane) which is extracted from underground or undersea reserves.
  • The process for liquifying biogas is the same as for LNG; the gas is cooled down to –162 °C. The fuel then takes significantly less space, which makes it possible to bring a much larger amount of energy onboard the truck, which increases the range significantly.
  • The EU Commissions goal (REPower EU) is to boost annual biogas production ten times to 35 billion cubic meters by 2030*. More than 78 bio-LNG plants are already confirmed to be ready in Europe by 2024. Germany and Italy, together with the Netherlands, are expected to be the leading bio-LNG countries in the coming years.
What is bio-LNG?
Bio-LNG is made from organic waste material, including household food waste, agricultural and industrial waste, as well as manure, sewage sludge and wastewater. Simply put, the waste material is broken down and purified to create biomethane. This is then cooled down to around -160°C, at which point it condenses and liquifies to create bio-LNG.
Bio-LNG is chemically equivalent to conventional LNG. It delivers the same performance and can be used in the same vehicles and refueling infrastructure. However, because it is made from organic waste rather than fossil natural gas, it is renewable and carbon-neutral as a tank-to-wheel fuel source.
In fact, when the biogas is produced from manure, the production process can even generate negative CO2 emissions of up to 200% (well-to-wheel).* This is because it not only prevents the release of carbon from burning fossil fuels, but also hinders the release of methane into the atmosphere that would ordinarily come from manure storage and processing. In other words, under this scenario, the net emissions from one gas-powered truck could cancel out the emissions from two diesel trucks.
Furthermore, because bio-LNG utilizes waste material, and the left-over digestate can be used as fertilizer, it contributes to a circular economy. It can also be produced locally, further eliminating carbon dioxide emissions from transportation.
and
How does the market for bio-LNG look?
Until recently, low production and insufficient refueling networks for gas-powered trucks have limited bio-LNG’s potential. However, that is changing.
The EU aims to increase biomethane production to 35 billion cubic meters (bcm) by 2030 as part of its REPowerEU plan. As of 2023, combined biomethane and biogas production is already up to 22 bcm. (The EU’s total natural gas consumption in 2023 was 295 bcm.) In the US, production of biogas has seen three years of record growth, with bio-LNG production representing over 90% of all new projects in 2023. Meanwhile China aims to produce 20 bcm of biogas by 2030.
Currently, there are 780 LNG refueling stations in Europe today, which are fully compatible with bio-LNG as production increases. China and India are also seeing strong growth in gas-powered trucks as an alternative to diesel, and are expected to see more extensive refueling networks in the coming years.
Which truck operations are bio-LNG best suited for?​
The advantage of a gas-powered truck is that it can deliver the same range and refueling times as a conventional diesel engine. For example, Volvo Trucks’ range of gas-powered vehicles have the same power and torque as their diesel equivalents, and can reach ranges of up to 1000 km.
See for more background information about biologically produced methane : posts 2 ,17 and 18.
post#2:
post#17:
post#18:
Who has not heard of the ISS (International Space Station) high above the Earth in the cold regions of space ?
A large group of astronauts do experiments there for science.
Oke, we have astronauts who live in the International Space Station.
As many people may know, us humans breath oxygen rich air in and breath air with mostly CO2 in it out. CO2 is of course : Carbon dioxide.
Problem is that in the vacuum of space there is no oxygen available and a build up of CO2 in the air inside the ISS is also not desirable. So CO2 scrubbers were developed decades ago.
These CO2 scrubbers take the CO2 in the air, out of the air and the CO2 is deposited and stored. When it is stored it is possible to reuse it.
The same type of carbon dioxide ( CO2) that is now present at too high levels in the Earth atmosphere causing the accelerated global warming of the planet.
More heat is trapped making weatherpatterns more unpredictable and more extreme, causing also that life on planet Earth is manipulated by these extreme weather conditions in ways we do not know.
And we really do not want that. To have extreme environments to live in, with lots of unknowns. A predictable positive way of life is a pleasant way of life. :blush:
Fast forward to today in 2025.
CO2 : Scrubber technology is available these days . Companies exist who can capture CO2 directly from the ambient air we are surrounded with and store it to be reused again.
This is called : Carbon sequestration.
For example the company : Skytree (EU) from the Netherlands but has also offices in the USA.
Skytree is a spin off from ESA, the European Space Agency.
These are very smart people, they really know what they are doing.
One of their products can capture over 600kg of CO2 a day, while the other product can capture up to 2500kg of CO2 a day.
One unit, that is 900 tons of CO2 a year that can be captured from the ambient air.
The 32minute video gives a lot of insight in how this all is done.
Addendum : Greenhouses need CO2. That is a good industry.
And there exist bacteria called methanogens, that convert CO2 into (bio) methane.
And we can use that biomethane to power for example our industries.
I have mentioned this a lot of times in this thread.
Background information about methanogens :
Small excerpt from text :
Conversion of CO2 into CH4 by methane-producing bacterium FJ10 under a pressurized condition
In this study, fresh water methane-producing bacterium (MPB), strain FJ10, which used H2 as an electron donor and CO2 as an electron acceptor, was isolated and chosen as the primary methanogen for the conversion of CO2 into CH4.
It seems lithium batteries will be in use for some time since large lithium deposits have been found in Germany and in Canada.
But in Germany there is also research going on to increase the energy density of lithium based batteries. Normally graphite is used for the anode but it seems that silicon is a much better choice when it comes to storing energy.
Small excerpt from the website text :
Conventional anodes – that is, lithium-ion cells’ negative poles – are made of graphite, which can store lithium at up to 370 milliampere hours per gram. Silicon, in contrast, can theoretically store up to 4,200 milliampere hours per gram – more than ten times as much as graphite. While silicon and graphite costs’ are comparable, silicon is abundantly available worldwide and thus more sustainable.
The problem is that with a lithium silicon battery , the silicon expands and contracts over 300 % during charging and discharging. This expansion and contraction of the silicon inside the battery damages the battery. This is more than a decade old problem but now German scientists have found a way to solve the problem. The approach they used, allows for 1000mA hours per gram, a 250% increase in storage ability.
The practical implications are enormous, easily double the driving range of EV vehicles. Or reduce the weight from the EV vehicles by halving the battery. Making smartphones that are lot less heavy while still having enough electrical storage capacity. Making all kinds of battery powered E-gadgets lighter in weight.
Website :
https://www.zsw-bw.de/en/newsroom/n...teries-energy-density-and-sustainability.html
FACILE project combines fiber, nonwoven, and semiconductor technologies
A new research project involving four partners based in Baden-Württemberg – one being the Centre for Solar Energy and Hydrogen Research Baden-Württemberg (ZSW) – aims to advance the state of the art in battery technology. Called FACILE, this project seeks to increase lithium-ion batteries’ energy content by developing innovative silicon-based anode materials. To this end, the industry and science consortium intends to combine proven paper and nonwoven production processes with sophisticated industrial coating techniques used in semiconductor and photovoltaic engineering. The goal is to boost the practical energy density on the anode side by up to 250 percent as well as to improve batteries’ environmental footprint. The Baden-Württemberg Ministry of Economic Affairs, Labor, and Tourism is funding the project with €1.28 million. Launched on July 1, 2025, it will run for 24 months, concluding on June 30, 2027.
and
Fibers, not fractures: Reinventing silicon anodes
The Baden-Württemberg-based partners in this project are determined to use silicon to increase the anode’s actual energy density by at least 250 percent, thereby achieving no less than 1,000 milliampere hours per gram of practical capacity. The great challenge is that silicon’s volume changes markedly during charging and discharging. Unless suitable countermeasures are taken, this soon causes cracks and peeling on the anode, which can result in battery failure. This is where FACILE enters the picture. It is the first attempt to develop silicon anodes on fiber-based, electrically conductive nonwoven substrates. Their flexible, fiber-based structure is designed to accommodate the volume changes in silicon. The resulting composite material pairs high performance and long service life with sustainability in an innovation that is truly ‘made in Baden-Württemberg.’
and
Building and validating test cells
The ZSW at Ulm started off by trialing in small test cells the fiber-based silicon anodes produced in the project. Next the scientists will analyze, refine, and scale up the production processes for manufacturing large battery cells such as those that power electric vehicles. The institute brings a great deal of expertise to this task: It operates several cell manufacturing pilot plants. One is a factory-like research production line for making large lithium-ion cells with up to 100 ampere hours capacity. It has been up and running since 2014.
ZSW scientists have amassed decades of experience assessing the safety and performance of batteries and prototypes. Set up in 1998, the institute’s battery safety and testing center is renowned across Europe.
Germany has discovered one of the world's largest lithium deposits, estimated at 43 million tons in the Altmark region of Saxony-Anhalt.
Also in Canada, satellite mapping in combination with AI algorithms has revealed enormous amounts of lithium deposits.
See websites :
Dutch site explaining in detail about silicon anode based lithium batteries , you can run the website through google translate for your native language :
English translation :
Amogy , developer of a catalyst that converts ammonia into hydrogen and nitrogen has a contract with samsung heavy industries to develop a system that can be used for at least for freight ships. But the possibilities are endless.
The hydrogen is then supplied to a massive fuelcell that converts oxygen and hydrogen into electricity. Leaving only clean pure water (H2O) as the byproduct. The nitrogen can be captured as well.
Small excerpt from website text :
At a high level, ammonia seems like a dream fuel: It’s carbon-free, energy-dense, and easier to move and store than hydrogen. Ammonia is also already manufactured and transported at scale, meaning it could transform energy systems using existing infrastructure. But burning ammonia creates dangerous nitrous oxides, and splitting ammonia molecules to create hydrogen fuel typically requires lots of energy and specialized engines. The startup Amogy, founded by four MIT alumni, believes it has the technology to finally unlock ammonia as a major fuel source. The company has developed a catalyst it says can split — or “crack” — ammonia into hydrogen and nitrogen up to 70 percent more efficiently than state-of-the-art systems today. The company is planning to sell its catalysts as well as modular systems including fuel cells and engines to convert ammonia directly to power. Those systems don’t burn or combust ammonia, and thus bypass the health concerns related to nitrous oxides.
and
Since Amogy’s founding in 2020, the company has used its ammonia-cracking technology to create the world’s first ammonia-powered drone, tractor, truck, and tugboat. It has also attracted partnerships with industry leaders including Samsung, Saudi Aramco, KBR, and Hyundai, raising more than $300 million along the way.
and
Earlier this year, Amogy completed a research and manufacturing facility in Houston and announced a pilot deployment of its catalyst with the global engineering firm JGC Holdings Corporation. Now, with a manufacturing contract secured with Samsung Heavy Industries, Amogy is set to start delivering more of its systems to customers next year. The company will deploy a 1-megawatt ammonia-to-power pilot project with the South Korean city of Pohang in 2026, with plans to scale up to 40 megawatts at that site by 2028 or 2029. Woo says dozens of other projects with multinational corporations are in the works.
Nowadays, generating electricity is usually done with a heat source that converts water into steam. This steam is then used to drive a turbine and the turbine drives a huge electrical generator.En there our electricity comes from.
To be able to do that we need a fuel for the heat source. Fuel like coal or natural gas is used to heat water in a boiler ,or nuclear reactions are used to boil water in a reactor. This all to create high-pressure steam.
As it turns out of course, converting water into steam is also energy consuming.
Over the years, steam engines and turbines have become more efficient, but the working medium has remained the same: water.
Scientists in the USA and China have discovered, however, that a significant amount of energy is lost in converting water into steam, a process that is both time-consuming and energy-intensive.
So , what the scientists did was instead of using water, the scientists use supercritical carbon dioxide (sCO2) instead of steam. This seems to be at least 50% more efficient in electricity generating.
While the overall efficiency of the powerplant in China is over 85% more efficient in comparison to a traditional powerplant that uses steam(water).
This all because supercritical carbon dioxide has both properties of a gas and liquid.
Imagine this :
Imagine that the MYRRHA accelerator driven subcritical nuclear reactor (fission) that is being build in Belgium is used to heat up the supercritical carbon dioxide (sCO2). This heated supercritical carbon dioxide is then used to power a turbine that drives an electrical generator.
The efficiency of such a system would be wonderful. Using thorium combined with nuclear waste. We would never have any power issues again.
We could stop with coal powered powerplants. Stop with gas powered power plants. Stop with traditional critical nuclear fission reactors.
We do no longer have to use huge fields of solar panels or create huge windturbine parks.
Being independent of the weather again.
Chaotan One, the world’s first commercial power generator that uses supercritical carbon dioxide (sCO2) instead of steam, has begun operations in China. This achievement breaks a century-old tradition of using steam for power generation, marking a major improvement in efficiency.
Water needs to be boiled first and needs to undergo a phase change to generate steam. Both steps are energy-intensive, and scientists have been looking for a better medium to replace them. They found this in sCO2.
What is sCO2?
Supercritical is a fluid state of CO2 gas where it is held above its critical temperature and pressure. We know that CO2 exists as a gas at room temperature and can be cooled to form dry ice by reducing pressure and lowering temperature.
However, when its temperature is raised to 87 °F (31 °C), and its pressure is increased to 1,070 psi (7.37 MPa), it enters its supercritical state.
In this state, CO2 exhibits properties of both a liquid and a gas.
Release it into a container, and it will fill the space, but it will have the density of a liquid. In applications such as moving a turbine, this is extremely useful, since the gas-like state offers less resistance while the liquid-like state provides greater thrust.
Equally importantly, turning CO2 into its supercritical state is less energy-consuming than turning water into steam.
Supercritical CO2 as a game changer
When CO2 is heated above 31 °C and 1070 psi (7.37 MPa), it enters a supercritical state where it exhibits both gas- and liquid-like properties.
Its gaseous nature ensures low resistance, while its liquid density provides more power to drive a turbine. More importantly, it takes less energy to supercritical CO2 than to convert water into steam. This allows significantly more of the energy used to actually be converted into electricity.
and
Chaotan One
The first commercial sCO2 generator, called Chaotan One, is located at a steel plant in Liupanshui, Guizhou.
The facility consists of two 15-megawatt units and was connected to the electricity grid last month. The plant utilizes waste heat from steel production to generate electricity, a smart way to increase industrial energy efficiency.
According to Chinese media , Chaotan One can increase net electricity generation by 50 percent compared to traditional steam technologies, while the overall efficiency of the plant can reach more than 85 percent.
Furthermore, the sCO2 turbine's design is simpler, contains fewer components, and is easier to maintain than conventional steam turbines. If Chaotan One stands the test of time, CO2 could become a standard medium and make steam technology less relevant.
A non-toxic stable material
The organization described supercritical carbon dioxide as a non-toxic, stable material that is under so much pressure that it behaves like both a liquid and a gas.
Because it stays within the system and is not released as a greenhouse gas, it can get much hotter than steam (1,290 degrees Fahrenheit or 700 Celsius). These temperatures allow it to be much more efficient at turning heat from power plants into energy.
About MYRRHA , see post#1
A good thorough explanation about how supercritical CO2 is very good to convert heat into mechanical movement and then into electricity by driving a turbine that is connected to an electrical generator. Better than steam from water.
The video explains how scientists in the USA and in China are independently working on the same solution : Replacing water with supercritical CO2 in powerplants to generate electricity. And with working systems and also the minuspoints to watch out for like that supercritical CO2 is very corrosive but that problem seems to be already solved by using nickel alloys for the pipes and turbines.
The scientists and engineers in the USA made a 4 MegaWatt prototype.
The scientists and engineers in China made two 15 MegaWatt commercial systems.
The End of the Steam Age? China’s Breakthrough CO2 Generator :
See post#84 for more information :
Yeehaw ! Finally researchers and scientists in the USA see the advantages of ADS (Accelerator Driven Systems) sub critical nuclear fission reactors. These nuclear reactors are a good way to produce energy because these kind of nuclear reactors can in principle not explode. This because the fuel used is thorium and what also can be used is present existing nuclear waste as a kind of MOX (Mixed Oxides) fuel.
sub critical nuclear fission reactors do not have enough neutrons to go to a critical nuclear fission reaction. The extra needed neutrons are produced by using a linac, a linear accelerator. This linac produces high power protons that are shot at a spallation target, this spallation target is a material that then starts to produce neutrons needed to make the reaction in the fuel go critical. The interesting part is that without the by spallation produced neutrons, the fission reaction stops immediately within microseconds. So no extra neutrons is no reaction. Also ,this kind of ADS sub critical nuclear reactors can be used to transmutate long lived actinides(nuclear material) into short lived isotopes that are far less radioactive.
I have often wrote about this , see post #1 about the MYRRHA project in Belgium on the continent Europe. See link below to post #1. And also in China, research is done to develop ADS (Accelerator Driven Systems) sub critical nuclear fission reactors.
But now researchers and scientists in the USA are also interested in ADS systems.
For details read the newsarticle on the website( Translated to English) :
American researchers want to stop burying spent nuclear fuel and instead use it as an energy source. Accelerator technology aims to reduce the lifespan of the most hazardous waste by three orders of magnitude—and generate additional CO₂-free electricity.
Researchers at the Thomas Jefferson National Accelerator Facility are developing a technology that could fundamentally shift the nuclear fuel cycle. Instead of treating nuclear waste as a permanent burden, it would be reused as fuel for new energy production via Accelerator-Driven Systems (ADS).
The projects are funded with $8.17 million from the Department of Energy's NEWTON program and focus on two core questions: can ADS technically operate continuously at high power, and can this be done at acceptable costs?
and
From 100,000 to 300 years
Spent nuclear fuel normally remains hazardous for up to about 100,000 years. With isotope separation and transmutation in an ADS system, researchers believe this can be reduced to about 300 years.
In such a system, a particle accelerator bombards a heavy target (e.g., liquid mercury) with high-energy protons. The spallation reaction produces many neutrons, which convert long-lived actinides into shorter-lived isotopes. The released heat can simultaneously generate electricity.
ADS has been researched for decades (including in Europe and Japan), but it has been economically challenging. Therefore, Jefferson Lab's work focuses on increasing efficiency and power density.
and
Strategic impact
The NEWTON program aims to make the entire US spent fuel inventory recyclable within 30 years. This would fundamentally change the discussion about permanent geological storage—such as deep geological repositories.
Instead of final storage, waste becomes an intermediate step in a closed fuel cycle. This aligns with international trends around partitioning and transmutation and the growing interest in advanced reactor concepts such as fast reactors and molten-salt systems, which better handle recycled actinides.
About MYRRHA in Belgium :
I often write in this thread about methane, not as a greenhouse gas but as useful gas since natural gas and the liquid variant : LNG is nothing more than methane.
I often have written in this thread that methane can be produced from waste from livestock waste, manure, agriculture waste, sewer waste and other biological waste materials.
Denmark has been working hard to reduce the dependency on foreign countries when it comes the natural gas. Which is just a positive side-effect of trying to reduce methane as a greenhouse gas emissions and have a circular energy production system.
Small excerpt from text from the website :
Nature Energy is a Danish-based company that is currently one of the largest biogas producers worldwide. The company operates 13 biogas plants in Denmark with several new plants currently in development. Annually, they process over 4.4 million tonnes of biomass, which consists of waste and residual products from agriculture, food production, and households.
At the facilities, the waste is converted to 181 million cubic meters of CO2-neutral biogas, which helps to replace fossil fuels. In 2022, Nature Energy was able to produce biogas equivalent to the heat consumption of 157,000 households.
“With our biomethane plants, we produce a stable supply of green gas and ensure agriculture efficient and valuable fertilizer based on the degassed biomass. This makes the entire energy production circular and profitable in a strong partnership with the local agriculture and business community,” says Ole Hvelplund, CEO of Nature Energy.
In the USA there are also many biogas projects. Biogas is just by methanogens (little bacteria that produce methane in oxygen poor environments) produced methane.
As an example , landfills breathe out methane. It is just the methanogens.
Of course in the Netherlands, state company Gasunie and commercial company Shell want to create a hydrogen industry and they will fail and it will cost the dutch taxpayers billions of euros. And it seems they prevent the development of biogas installations in the Netherlands... Sigh...
I would like to do a follow up on post #87 here above.
It seems that within shell there are at least 2 camps : The hydrogen camp and the biogas camp.
As it turns out, nature energy has been acquired by shell in November 2022.
And on the Shell page after some searching there is whole lot of information about the how and the why of biogas(biomethane).
Imagine running a farm. The rye and wheat from your land end up in the bread that feeds people. But the leaves and stems of the crops—those are not very useful. Enter Shell Biogas, the new name (as of September) for the originally Danish company Nature Energy. In Denmark, biogas has a long tradition. In countries like the Netherlands, it is less established, but Shell aims to expand its presence here over the coming years with the alternative for natural gas.
and
Nature Energy: biomethane producer since 1979
Shell Biogas’ predecessor, Nature Energy, has been working to establish itself in the Danish market as a biomethane producer since 1979. By 2022, when Shell announced its acquisition of the company, Nature Energy operated fifteen installations and employed 400 people. With renewed investments, the company grew rapidly—from four biogas plants in 2018 to becoming Europe’s leading biogas producer.
In 2022, its annual production exceeded 180 million cubic metres (6.4 billion cubic feet) of biogas, which has the same composition as conventional natural gas. For comparison, households in the Netherlands—a natural gas high-usage country—need about 1,200 m³ (42,377.6 ft³) gas per year.
Of Shell Biogas’ fifteen plants, thirteen are located in Denmark—ten of which are on the mainland, Jutland (Jylland). There is also one plant in France and one in Almere, the Netherlands. The Almere facility is slightly smaller than the standard installation and is currently temporarily idle.
And a Danish website :
Previously, the major share of biogas was used for electricity production, but today around 80 pct. is upgraded and feed into the natural gas grid, and this development towards upgrading is expected to continue in the future. In 2023 the share of biomethane in the Danish gas system reached almost 40 pct. and by 2030 Danish gas consumption is expected to be 100 pct. green.
Read more about the role of biogas in the green transition: Green Gas Strategy
China is going forward with the CiADS initiative.
  • Now we have China working hard to get the CiADS initiative operational.
  • We have Belgium working to get the MYRRHA initiative operational (See post 1 of this thread).
  • In the USA, researchers at the Thomas Jefferson National Accelerator Facility are working hard to prove the viability of ADS ADS (Accelerator Driven Systems) sub critical nuclear fission reactors.
Scientific goals:
The CiADS program is intended to carry out scientific research on the stability, reliability and long-term operations of the superconducting linear accelerator, high-power spallation target and sub-critical reactor core/cladding, and then step by step realize the coupling operation of the whole system from low power to high power. In addition, it is aimed at launching experimental exploration for the transmutation principle of minor actinides and developing the ADS system engineering and control system with independent intellectual property rights, so as to pave the way for the industrial demonstration facility and full-size technological integration in the next stage.
Project objectives:
The CiADS program is expected to build up the world's first high power coupling operation ADS facility at megawatt level (themal power in total ~10 MW), including ~2.5 MW beam power, ~7.5 MWth reactor power, with more than 24 hours of single full power coupled operation.
CiADS consists of four major components:
1. The superconducting proton linear accelerator (sc-Linac), a 350m-long linac, will provide protons at the energy of 250MeV with 2.5MW power. There will be an ion source, a low energy beam transport line, a RFQ accelerator, a medium energy beam transport line, a superconducting accelerator, a high energy beam transport line and a beam dump included. It has a spare room for upgrading to 1.5 GeV.
2. The high power lead-bismuth eutectic (LBE) spallation target, coupled with the reactor and designed to withstand maximum beam power at 2.5MW, will contain a target body, a linac/target coupling system and the remote operation and maintenance system for replacing the target window. In the meantime, an experimental terminal will be set up to verify a new concept for the high-power spallation target, the gravity-driven dense granular target (DGT), which is proposed as a potential technology for the future industrial ADS facility.
3. The sub-critical reactor, with lead-bismuth eutectic (LBE) as the coolant, a spallation target window reserved on the reactor roof and a pool-type design main container, can simultaneously achieve the coupling and physical isolation with the spallation target. A passive containment thermal conduction system will be used to ensure the safety of the sub-critical system in the accident conditions.
Translated to English :
Enough energy for the next 1,000 years​
ADS technology combines a nuclear reactor with a high-energy particle accelerator. Unlike traditional nuclear reactors, which rely on a self-sustaining chain reaction, this subcritical system requires an external source of neutrons to remain active.
Superconducting linear accelerators fire proton beams at 80% of the speed of light at a liquid lead-bismuth alloy. This creates a massive neutron flux. These neutrons convert uranium-238, often considered waste, into plutonium-239, effectively transforming the "waste" into usable fuel.
The reactor cannot sustain the reaction independently. This makes an uncontrolled meltdown physically impossible and significantly increases safety.
The ADS concept isn't new and has existed since the 1980s. Yet, no commercial installations are operational worldwide. China began dedicated research in 2011, with a prototype in 2021 that reached operational intensity for industrial use. With the megawatt-scale project in Huizhou nearing completion, China is positioning itself as a global leader in the transition to a "closed" nuclear fuel cycle.
He Yuan calls the project an internationally recognized ideal approach to nuclear fuel production and waste treatment: “It makes nuclear energy green, safe and stable.” The installation of the crucial superconducting accelerators is expected to be completed by the end of 2026, with full operational capacity in 2027.
