I think what your seeing is the processors normal down clocking in certian workloads, it still fluctuates with the mod. Undervolting the cpu's vcore should help cause power usage is a down clocking factor. Undervolting by - 0.070 volts is in the ballpark range to keep it stable.Good afternoon! Is there a driver that will make 2690 v3 work on 3.49 in all tests? Because now the processor sometimes drops to 3.38
Hey did you ever get one? I have the same board with a e5 1280 v3Hello, I got a MSI x99A-SLI-Plus with an AMI Aptio V. Is there a guide to do the mod with this type of bios? Is mmtool the way to go, I believe theres a version of it that can mod this Aptio V bios.
Thank you so much as no matter how i did the mod it wouldn't work for me.Here is the mod.
Use M-FLASH in BIOS
MOF_V3_705050 ffs + 306F2 mCode removed + Disabled C6 State(in IntelRCSetup) : https://drive.google.com/file/d/1qazvvMw4e58swLXwUGnqd4T8r8StF0R4/
I'll try it out and share my e5 2690 v3 results later today.Thank you so much as no matter how i did the mod it wouldn't work for me.
Update: It is installed and worksat first but then defaults down to 2.9GHz on all cores. also I get a current limit throttling and it doesn't go away. even at idle I am throttling
yeah let me know if it works what settings you have in the bios as i may have something aset wrong. this board may just be bad though considering I can't get my cards to run at x16. may just have a bad board.I'll try it out and share my e5 2690 v3 results later today.
it works now yes. Btw i have one more favor. Can you do the mod with this bios instead https://download.msi.com/bos_exe/mb/7885v18.zip ?Try use Cinebench R15, Prime95 (without AVX, Small FFT’s), AIDA64 Cache & Memory Benchmark
Intel XTU Benchmark is useless for check Turbo Unlock.
Any bios after 1.9 is very unstable on my board. I just bsod'ed playing elder scrolls online. that tells you how bad it is.
drive.google.com
Thank you so much. Everything is stable and perfect. I'm not sure why it didn't work when I tried to mod it but you got it perfectly.Here 🙂
V3_MOF_505050 (For Stable) + 306F2 mCode Removed + Disabled C6 State
7885v18_MOD.zip
drive.google.com
Here is the mod.
Use M-FLASH in BIOS
Everything works fine for me, on cpuz's normal stress test I get the full 3.5 Ghz turbo boost on all 12 cores. Its avx 2 benchmark and prime95 only throttle to 3.4 Ghz. 🙂 THANK YOU Scan409, your a true credit to team.Thank you so much. Everything is stable and perfect. I'm not sure why it didn't work when I tried to mod it but you got it perfectly.
Assume the above modded bios will work MSI X99A Gaming 7 aswell?
They list the latest firmware as 7885vHH2 here:
MSI Global - The Leading Brand in High-end Gaming & Professional Creation
As a world leading gaming brand, MSI is the most trusted name in gaming and eSports. We stand by our principles of breakthroughs in design, and roll out the amazing gaming gear like motherboards, graphics cards, laptops and desktops.www.msi.com
Will give it a shot when I get some spare time
what is this in particular? the mod as an official thing with the x99-ud5-wifi mobo?
EDIT nvrmind. I just seen what it is: trash. I have this motherboard coming. Now i need to remod.
What's the difference between the two? Also will tabbing work in efi flash. Im not used to flashing a mobo this way? Is it possible to use the emergency qflash thingy built in?Here is the mod
MUST USE efiflash 0.65_mod or 0.80_mod in DOS
ex) efiflash.exe [BIOS file]
GIGABYTE X99-UD5 WiFi : https://drive.google.com/file/d/1DC7te-6ZXO7ydcpSFZiyfJzv7M-n_QVk
efiflash 0.65 mod : https://drive.google.com/file/d/1jLAeWdsvIOPx5HCQvjIGb9vfPReKyLRl/
efiflash 0.80 mod : https://drive.google.com/file/d/1fQizIvfRjGbAnsN-HCZZ-iC-DyCEqZA8/
ok thanksVersion 0.80 is the latest version of GIGABYTE efiflash Tool.
Support Intel 300 Series and AMD 500 Series Chipset Motherboard.
I recommend version 0.65, but you can use version 0.80 too.
In my experience, the GIGABYTE Q-FLASH function was unstable and buggy.
It was more stable to proceed with efiflash.
Last, I'm not using GIGABYTE Motherboard anymore. So I can't guarantee of this model.
Hi, I'm using the exact same motherboard and CPU's! I was able to backup BIOS and flash it without EPROM programmer with help of afudos and free dos.I tried with a e5 2620v3 with One of my z10pa d8 and all goes well..
So the cpu under strees up ti 3.2 GHz.... Only a thing ,why does the RAM recognize ti 1833 instead 2133???? Is there some option to set this valute?
