watdahel
Golden Member
When formatting a drive the Allocation Unit Size defaults to 4 Kilobyte. Increasing this will in effect increase average file sizes on the drive. Doesn't that mean larger blocks of data will be moved around during drive wear levelling and cause the drive to fail sooner? For example, if the Allocation Unit Size is set to 2 MB, then a 1 KB text file will occupy the full 2 MB block on the drive. If the text file is modified or erased then the 2 MB block gets rewritten to another 2 MB block or gets erased. On the other hand, with a 4 KB Allocation Unit Size this will result in only a 4 KB block getting rewritten or erased.
