Discussion Zen 5 Speculation (EPYC Turin and Strix Point/Granite Ridge - Ryzen 9000)
Page 1011 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
I don’t want an ASUS tuf. What now?
why are they porting RDNA3.5 to N3 then?
That's my question. I suspect that RDNA 5 is a notable XTOR count increase per WGP, and a much smaller RDNA 3.5 iGPU is still more than capable of being effective in poverty markets. The 8CU in KRK does a good job keeping up with the 12CU unit in HWK on actual game performance. We see that with FSR3.x, it's enough for most games to drive a 1080p display well enough to be usable. Even the 4CU unit in KRK2 isn't awful.
Why would poverty markets need N3? They could keep on selling N4 RDNA3.5 in those areas.
You know people don’t have to justify whatever AMD does as sane. If Zen5 isn’t good to port over to N3 then RDNA3.5 isn’t either. A waste of time.
They aren't going to stop producing KRK and KR2 any time soon. Those are going to have a market they they will sell into for a long time. They still produce HWK in volume and there are still PHX2 products available for sale, though I don't shop in that market so I don't see many.
WCL is not a bad product, and AMD will need something for that and 4Xe PTL going forward. Low end Medusa will handle that well enough.
Since Medusa 1 die is N3P, then AMD is obviously porting RDNA3.5 to N3P.
Interesting question is which process technology AMD will use for Zen 6 desktop IO dies.
If it is N6, we may still be stuck on RDNA2. More likely, it will be N4 (N4C?) and we end up with RDNA3.5 and AMD may add some other things that commercial OEMs ask for in desktop chips (NPU).
Maybe AMD should have been selling (and bundling) M2 sticks with NPU.
DDR5-4800 vs. DDR5-6000 Performance With The AMD Ryzen 7 9850X3D In 300+ Benchmarks​
Well, full Zen 5 using DDR5 6000 gets bandwidth of 96 GB/s and single CCD can only use 64 GB/s write and 32 GB/s write.
Reducing memory speed to DDR5 4800 reduces bandwidth to 76.8 GB/s which is still more than 64 GB/s a single CCD can use.
So, the bandwidth is unaffected only memory latency is affected.
Probably other things are going on, such as DDR 6000 being synched to the Infinity Fabric clock and if DDR 4800 also has the clock synched, it would mean lower bandwidth to CCD and if it is not synched, then some other losses take place...
It's an 8Q cadence with client SoC uncore being the lowest priority (GPGPU > server > GPU > client SoC).
Well, the results show it. AMD can achieve some competitiveness, briefly and then, with no follow up, loses it.
At this pace and with this attitude, AMD will be #5 of the 5 notebook vendors. Behind:
- Intel
- Apple
- Qualcomm
- NVidia
They all invest more and they all take the market more seriously.
Is there any surprise then how the notebook OEMs went exactly as much on the limb for AMD as AMD goes out on the limb about the notebook market?
So, Zen 5 can hold its on in the CPU core area, even on N4, but the uncore stinks.
Which is the reason AMD should be iterating the uncore annually until they catch up.
AMD core power results are questionable.
I'm hoping geekerwan does some idle normalized core power curves. Though IIRC his spec 2017 numbers for AMD (perf, not power) were some straight buns.
What is H445 and H350??
AMD Zen 5 strix point and gorgan point skus.
Mem speed is whatever (just don't triple stack DDR PHYs and you'll hit relevant ones).
I mean node and packaging and cache ratios and the uncore.
Venice is really $$$ but man does it win some.
Just saying as there were some benches that liked MRDIMMs.
EPYC with each generation has systematically reduced the number of workloads Intel is viable in each time, Venice makes this nearly absolute.
- Intel
- Apple
- Qualcomm
- NVidia
What matters is CAGR, make a big enough leap every 2 years and all is well.
New roadmap is alternating CPU and GPU updates, is quite nice really.
Battle of the 128 core CPUs. Granite Rapids vs. Turin full cores. I thought Granite Rapids was closer, in performance:
Well, I have a pair of 9755's, just not in the same motherboard, and they rock ! And destroy everything else I have, and that's saying something.
edit: so bad in fact that my retail 9654 is powered down, as its not worth it for the first time in years. The 128 9755's do twice the work or more at only 25% more power, if that !
