DisEnchantment
Golden Member
Speculate at will
AMD did say as much about Zen 3, however, as moinmoin points out…Zen 5 was said to be a new architecture with a grounds up design.... but so was zen 3. And yes, zen 3 was really impressive, no doubt about it, but I doubt it would be 'a new reset for CPU architecture at AMD' like zen was for them.
Personally I am expecting something like zen 3 or Golden Cove levels of increases.
But hey who knows 🙂
The thing about these ground up designs is not that all of the core changes, many of the blocks are still the same. Even Zen 1 did lift significant blocks from the previous construction cores. Between every gen work on blocks is done were deemed necessary and fruitful. With every even gen the blocks are optimized within the given structure, making the most of that ("picking low hanging fruits"). With every odd gen the way all those block are connected and interact is essentially reset and rethought, removing structural bottlenecks and making better use of all the blocks, and that's the big deal. That step is exactly for avoiding getting into dead ends of diminishing returns that would be the result of never touching the fundamental structure.
Just some thoughts.I'm also fairly confident in the "asymetric cores with the same ISA point" option, considering into what lengths AMD went to add everything but the kitchen sink to Zen 4. It would also help to compensate for the inevitable die-size bloat a much wider core would bring.
"We are already heterogeneous. I can’t even think of homogenous, monolithic part going forward." - Forrest Norrod
Zen 3 in AMD words were ALSO a completely new architecture. Both were called a new "Ground up" architecture.Zen 5 in AMD words will be not only a completely new architecture but it will also go wider (probably in both decode and execution). So I will not base my prediction in what happened with the Zen2 to Zen 3 transition, because it should be more AMD's "Golden Cove" moment, or even more extreme than that.
Could be possible, but the reveal that would we be getting zen 5 vanilla and then zen 5 V-cache makes me think that any form of stacking is still too expensive for AMD without having to separately segment it. At the very least, I would expect what you are proposing would be only for some skus.Just some thoughts.
One thing I wonder about this is that if the L3 is fully 3D stacked, underneath the core, they can put a dense CCX and high frequency CCX on top of unified L3 . Bypassing the IFOP/IOD for inter CCX CC snooping.
Current dual CCDs chips are already differing 300+ MHz in clock speed between CCD0 and CCD1 and the ACPI CPPC preferred core handling is already a thing in Windows and Linux moving the task to the fastest cores possible.
Let's say a 4.5 GHz dense CCX and 6 GHz Fast CCX which are exact instruction compatible would make the CPU very transparent to software, during all core loads the entire chip runs at 4.5 GHz anyway and during bursty ST loads the preferred core takes over. Pretty much like any 5950X or 7950X when you enable CPPC preferred core in BIOS.
Also really curious about the IFOP going away or is gonna remain, replaced by EFB or interposer things
I have seen AMD folks working on N3 GMI PHYs with double the BW of current N5 PHYs.
GMI2 --> Up to 25 Gbps SerDes, GMI3 --> 32-26 Gbps SerDes, GMI4 --> Up to 64 Gbps SerDes. Not sure what to make of that.
That is why I find the un-core really the most interesting thing to look forward to in Zen 5.
The core is like yeah 50% bigger PRF/decode/execute etc. etc. but the un-core is the total wild card.
Unfortunately there will hardly be any leaks around as usual for AMD. We have to go by some vague statements like these
That's the case for quite a long time now though. After the (glorious) change from Zeppelin to CCDs (Zen 1 to Zen 2) I was expecting more with Zen 3, but the IOD setup stayed the same. Even with Zen 4 it mostly stayed the same aside finally incorporating lessons from mobile chips as well as a minimum specification iGPU.The core is like yeah 50% bigger PRF/decode/execute etc. etc. but the un-core is the total wild card.
Considering all the changes introduced in both the desktop and server IO dies this year (DDR5, PCIe 5.0, CXL, iGPU, etc), I doubt we'll see any significant changes till Zen 6. Maybe small feature tweaks or speed bumps, but I think they'd want to reuse it for next gen.That's the case for quite a long time now though. After the (glorious) change from Zeppelin to CCDs (Zen 1 to Zen 2) I was expecting more with Zen 3, but the IOD setup stayed the same. Even with Zen 4 it mostly stayed the same aside finally incorporating lessons from mobile chips as well as a minimum specification iGPU.
Let's see whether Dragon Range and Bergamo change anything about the IOD. Siena obviously will be a new smaller server IOD (right? right??). With these AMD may or may not change the uncore more and more often before Zen 5 already. We will see, I sure want more to happen in that particular area.
What about SH5 socket/MI300? This is a Zen 4 based product.That's the case for quite a long time now though. After the (glorious) change from Zeppelin to CCDs (Zen 1 to Zen 2) I was expecting more with Zen 3, but the IOD setup stayed the same. Even with Zen 4 it mostly stayed the same aside finally incorporating lessons from mobile chips as well as a minimum specification iGPU.
Wider is important, but AMD themselves said going wider and wider ends up having diminishing returns.
Zen 3 deserved to be called a new arch by lineage alone. If anything, perhaps more so than Zen 5.In more than one interview AMD also declared that Zen5 would have been a radical departure from the current design paradigms and that it would have been something quite different from what we have seen before. Zen3 was called a new architecture already before launch, but never once a "paradigm shift".
By this logic, Zen 5 belongs to Zen 3 family. But I can understand your perspective. Some folks have a horse in this race, some elsewhere (in fact same industry for me, and my career progression depend on our race horse performance).Zen 3 deserved to be called a new arch by lineage alone. If anything, perhaps more so than Zen 5.
A true paradigm shift for me can mean for example abandoning the approach of a core with fixed resources and fixed number of threads it can serve, but instead having some large pool of resources, which could be dynamically assigned to tasks. If you required a few demanding threads, you could give them a lot of resources (effectivelly creating a few super powerfull "fat" cores), if you had a ton of threads, it would work as if you had a lot of compact cores serving e.g. 4 threads each.In more than one interview AMD also declared that Zen5 would have been a radical departure from the current design paradigms and that it would have been something quite different from what we have seen before. Zen3 was called a new architecture already before launch, but never once a "paradigm shift".
It's exactly why I think Zen 5 is another Zen 3 level change, maybe slightly higher, but nothing enormous like the 40-50% IPC gains that people are talking about. I feel like when that occurs, they will move of the zen name, at the very least for branding/marketing purposes.Zen 3 deserved to be called a new arch by lineage alone. If anything, perhaps more so than Zen 5.
I agree, and I strongly believe that if Intel's "Royal Core" project is as 'paradigm changing' as it is rumored to be, then this is what they could be aiming for. Intel has certainly looked into this before- they even purchased the company that has been planning on releasing an architecture that did exactly this- Soft Machines.A true paradigm shift for me can mean for example abandoning the approach of a core with fixed resources and fixed number of threads it can serve, but instead having some large pool of resources, which could be dynamically assigned to tasks. If you required a few demanding threads, you could give them a lot of resources (effectivelly creating a few super powerfull "fat" cores), if you had a ton of threads, it would work as if you had a lot of compact cores serving e.g. 4 threads each.
Royal or the Soft Machines stuff?However, Ian Cutress seems to think that this project seems to have been mothballed internally at Intel, maybe due to poor performance scaling or other factors, so I'm not betting on it...
The soft machine stuff, where you have a global front end and a bunch of cores, which can combine to act as larger cores while sharing resources, etc etc.Royal or the Soft Machines stuff?
Zen 5 somehow has to redo a lot of CCX layout like Zen 3 did. Their Zen 5 lineup reportedly consists a 256c server SKU, that's why.By this logic, Zen 5 belongs to Zen 3 family. But I can understand your perspective. Some folks have a horse in this race, some elsewhere (in fact same industry for me, and my career progression depend on our race horse performance).
But otherwise, Zen 5 is a new architecture, it has been years in development and it will deliver. Just like how Zen and Zen 3 did and as planned.
The Zen 5 program has been in the making for a long time, architecture should be frozen for quite a bit now including RTL design, high level simulations etc. The physical implementation would already be coming to a close and they would need to tape out in 1Q or 2Qs at the latest to meet the 2024 deadline.
Yeah, CDNA is where all the interesting uncore and package development is right now.What about SH5 socket/MI300?
Such kind of "true paradigm shifts" won't happen unless they are supported by software and OSes out of the box. That alone unfortunately prevents some fundamental changes to happen. Alder Lake with its P- and E-cores, despite working out of the box, already showcases how little software is being actually optimized.A true paradigm shift for me can mean for example abandoning the approach of a core with fixed resources and fixed number of threads it can serve, but instead having some large pool of resources, which could be dynamically assigned to tasks.
Just curious, what sort of financial compromises do you think AMD did with zen that had to do with design?What makes Zen 5 stand out is that it's the first ground up design under the new current AMD. Zen 1-3 were all planned and executed during AMD hardest money starved near bankruptcy years. Zen 4 is an extension of Zen 3. Zen 5 is the first design (and AM5 a platform) where AMD needn't do any compromises for financial reasons. That alone should make it a big deal.
No concrete idea! But AMD may have been short on staff, have less budget for R&D for more advanced packages, less budget for more extensive simulations of all technical possibilities etc. pp. Just keep in mind that the primary reason AMD went MCM and then chiplets while doing as few different distinct die designs across a large product range as possible wasn't because they could and for fun but because that was the only way they could afford targeting the TAM they did.Just curious, what sort of financial compromises do you think AMD did with zen that had to do with design?
That makes sense. I think they are going to start designing more custom dies for more specific segments, we already see examples with V-cache, but it's also really interesting how they have both 3nm and 4nm variants of zen 5.No concrete idea! But AMD may have been short on staff, have less budget for R&D for more advanced packages, less budget for more extensive simulations of all technical possibilities etc. pp. Just keep in mind that the primary reason AMD went MCM and then chiplets while doing as few different distinct die designs across a large product range as possible wasn't because they could and for fun but because that was the only way they could afford targeting the TAM they did.
Another clear difference from before is additional different core die variants as in Zen 4c/Bergamo and additional different platforms as in SP6/Siena. Maybe also mobile depending on the extend Dragon Range deviates from Raphael and Phoenix Strix deviates from the previous painter APU series. All these will continue with Zen 5 as well.That makes sense. I think they are going to start designing more custom dies for more specific segments, we already see examples with V-cache, but it's also really interesting how they have both 3nm and 4nm variants of zen 5.
